Inleiding
The Sony SRS-XE200 is a popular Bluetooth speaker known for its portable design and impressive sound quality. However, like any electronic device, it may encounter issues with its built-in microphone over time. If you're facing problems with the microphone on your Sony SRS-XE200, such as poor audio quality or malfunction, you may need to replace it. Microphone replacement can be a technical process that requires careful handling and attention to detail.
Wat je nodig hebt
Remove the five 1 mm screws connecting the motherboard to the case with a Phillips #1 screwdriver.
Separate the motherboard from the case.
Remove the two 0.8 mm screws connecting the motherboard to the microphone with a Phillips #1 screwdriver.
Remove the microphone.
