Ga door naar hoofdinhoud
Sony SRS-XE200 Battery Replacement
Wat je nodig hebt
  1. Sony SRS-XE200 Battery Replacement, Speaker Assembly: stap 1, afbeelding 1 van 2 Sony SRS-XE200 Battery Replacement, Speaker Assembly: stap 1, afbeelding 2 van 2
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
  2. Sony SRS-XE200 Battery Replacement: stap 2, afbeelding 1 van 1
    • Pry the rubber cap away from the body of the speaker using a spudger.
  3. Sony SRS-XE200 Battery Replacement: stap 3, afbeelding 1 van 2 Sony SRS-XE200 Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
  4. Sony SRS-XE200 Battery Replacement: stap 4, afbeelding 1 van 2 Sony SRS-XE200 Battery Replacement: stap 4, afbeelding 2 van 2
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
  5. Sony SRS-XE200 Battery Replacement, Battery: stap 5, afbeelding 1 van 3 Sony SRS-XE200 Battery Replacement, Battery: stap 5, afbeelding 2 van 3 Sony SRS-XE200 Battery Replacement, Battery: stap 5, afbeelding 3 van 3
    • Remove the five 1 mm screws connecting the motherboard to the case with a Phillips #1 screwdriver.
    • Separate the motherboard from the case.
  6. Sony SRS-XE200 Battery Replacement: stap 6, afbeelding 1 van 3 Sony SRS-XE200 Battery Replacement: stap 6, afbeelding 2 van 3 Sony SRS-XE200 Battery Replacement: stap 6, afbeelding 3 van 3
    • Remove the battery from the battery holder with a nylon spudger.
    • Unplug the battery from the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
2 opmerkingen
Thanks what is the replacement battery number?
fred Pope - Antwoord
What is the battery number for the SRS replacement
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 32
Altijd: 566
