Inleiding
In this guide, you will learn how to disassemble the speaker housing first, and then how to replace the actual speaker itself. This is a quick and easy replacement guide.
Wat je nodig hebt
Remove the speaker case from the outer casing by prying it from the base of the speaker using a metal spudger.
After you have gotten the speaker plate off of the main body of the speaker, there will be two PH1 10mm screws that hold on the speaker.
Using the screwdriver and PH1 head from your toolkit, unscrew the 2 screws and place them to the side.
4 opmerkingen
Where can i purchase a replacement speaker?
Where do I get the replacement speaker?
https://www.olx.ua/obyavlenie/odin-dinam...
this store in ukraine
I broke my speaker case. It’s the black, plastic protective case that is in front of the speaker. Where can i get a new replacement part?
