Ga door naar hoofdinhoud
Sony SRS-X7 Faceplate Disassembly
Wat je nodig hebt
  1. Sony SRS-X7 Faceplate Disassembly, Sony SRS-X7 Faceplate Disassembly: stap 1, afbeelding 1 van 2 Sony SRS-X7 Faceplate Disassembly, Sony SRS-X7 Faceplate Disassembly: stap 1, afbeelding 2 van 2
    • On the bottom of the device, you'll see 4 rubber pieces at the corners. Peel off these rubber pieces.
    • Unscrew the 4 10mm Philips J1 screws beneath them.
  2. Sony SRS-X7 Faceplate Disassembly: stap 2, afbeelding 1 van 3 Sony SRS-X7 Faceplate Disassembly: stap 2, afbeelding 2 van 3 Sony SRS-X7 Faceplate Disassembly: stap 2, afbeelding 3 van 3
    • The black stickers between the 4 foam pieces are there to protect the unit's warranty. If you try to send the device back to Sony after poking through said stickers, they will not accept it as the device has been tampered with.
    • Poke through said stickers and unscrew the 2 10mm Philips J1 screws beneath those.
    • Insert the blue plastic tool into the corner of the bottom faceplate and slide along the edge.
    • It will be a bit difficult as there is adhesive holding the faceplate to the unit, but with it bit of playing it should come off with ease.
  3. Sony SRS-X7 Faceplate Disassembly: stap 3, afbeelding 1 van 2 Sony SRS-X7 Faceplate Disassembly: stap 3, afbeelding 2 van 2
    • Using a metal spudger, insert it into one of the corners or sides of the units faceplate and lightly pry open.
    • While pried, insert a plastic opening tool and slide along the edges of the unit.
    • Repeat the last step on each side of the unit's faceplate, until the faceplate is off.
    • The first time you attempt to take the faceplate off of the speaker, it will be difficult because there is adhesive holding it to the unit. After this time, disassembly and reassembly should be easier.
  4. Sony SRS-X7 Faceplate Disassembly: stap 4, afbeelding 1 van 2 Sony SRS-X7 Faceplate Disassembly: stap 4, afbeelding 2 van 2
    • With the faceplate now off, the speakers should be revealed. There should be 8 visible screws around the border of the speakers. Remove the 8 10mm Philips J1 screws.
    • Take the 2 20mm Philips J1 screws out of the middle of the speaker as shown.
  5. Sony SRS-X7 Faceplate Disassembly: stap 5, afbeelding 1 van 2 Sony SRS-X7 Faceplate Disassembly: stap 5, afbeelding 2 van 2
    • The speaker should come out of the unit with ease, however you should use caution as it is still connected to the motherboard.
    • Take the whole speaker out, and disconnect the connectors from the motherboard by lightly pulling on them.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Tyler Lamar
685 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 7-6, Catania Spring 2016 Lid van UMass Dartmouth, Team 7-6, Catania Spring 2016
UMASSD-CATANIA-S16S7G6
3 Leden
Één opmerking
can the battery be replaced?
Daniel Reverter - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 22
Altijd: 3,190
