Ga door naar hoofdinhoud
Sony SRS-X55 Speaker Reverberator Replacement
Wat je nodig hebt
  1. Sony SRS-X55 Speaker Reverberator Replacement, Speaker Reverberator: stap 1, afbeelding 1 van 1
    • Locate the six 9 mm screws on the bottom of the speaker and remove them using Phillips head #2.
  2. Sony SRS-X55 Speaker Reverberator Replacement: stap 2, afbeelding 1 van 2 Sony SRS-X55 Speaker Reverberator Replacement: stap 2, afbeelding 2 van 2
    • Insert a plastic spudger into the seam on the bottom panel and lift it away from the rest of the speaker.
  3. Sony SRS-X55 Speaker Reverberator Replacement: stap 3, afbeelding 1 van 3 Sony SRS-X55 Speaker Reverberator Replacement: stap 3, afbeelding 2 van 3 Sony SRS-X55 Speaker Reverberator Replacement: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Locate the battery connection and unplug it using a pair of metal tweezers.
  4. Sony SRS-X55 Speaker Reverberator Replacement: stap 4, afbeelding 1 van 2 Sony SRS-X55 Speaker Reverberator Replacement: stap 4, afbeelding 2 van 2
    • Locate the remaining two 3.5 mm screws on the bottom of the I/O board and remove them using a Phillips head #2 screwdriver.
  5. Sony SRS-X55 Speaker Reverberator Replacement: stap 5, afbeelding 1 van 1
    • Remove the I/O board from the rest of the speaker. A plastic spudger can aid in this process if it is inserted into the edge as shown and gently pried.
  6. Sony SRS-X55 Speaker Reverberator Replacement: stap 6, afbeelding 1 van 2 Sony SRS-X55 Speaker Reverberator Replacement: stap 6, afbeelding 2 van 2
    • Insert a plastic spudger into the seam where the forward facing metal speaker cover meets the speaker body and gently pry it upward until it releases.
  7. Sony SRS-X55 Speaker Reverberator Replacement: stap 7, afbeelding 1 van 2 Sony SRS-X55 Speaker Reverberator Replacement: stap 7, afbeelding 2 van 2
    • Locate the eight 8.9 mm screws on the face of the speaker assembly and remove them using a Phillips head #2 screwdriver.
  8. Sony SRS-X55 Speaker Reverberator Replacement: stap 8, afbeelding 1 van 2 Sony SRS-X55 Speaker Reverberator Replacement: stap 8, afbeelding 2 van 2
    • Insert a plastic spudger underneath one of the tabs on the front of the speaker assembly and gently raise it.
    • Continue to the next step before attempting to lift the speaker assembly entirely away from the rest of the speaker to avoid damaging internal wire connections.
  9. Sony SRS-X55 Speaker Reverberator Replacement: stap 9, afbeelding 1 van 3 Sony SRS-X55 Speaker Reverberator Replacement: stap 9, afbeelding 2 van 3 Sony SRS-X55 Speaker Reverberator Replacement: stap 9, afbeelding 3 van 3
    • Locate the two wire connections as shown underneath of the speaker assembly and unplug them using a pair of tweezers.
    • Lift the speaker assembly away.
  10. Sony SRS-X55 Speaker Reverberator Replacement: stap 10, afbeelding 1 van 2 Sony SRS-X55 Speaker Reverberator Replacement: stap 10, afbeelding 2 van 2
    • Locate the eight 7.5 mm screws across both of the speaker reverberators and remove them using a Phillips head #2 screwdriver.
    • Lift the speaker reverberators away and replace them.
Conclusie
Eric Coletto
113 Reputatie
1 Handleiding geschreven
IUPUI, Team 2-3, Baechle Spring 2017 Lid van IUPUI, Team 2-3, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G3
3 Leden
3 handleidingen geschreven
Één opmerking
Nice Guide, but do you know the exact speaker size and/or type?
I can not find the exact speakers.
THX
Elduderino79
El Duderino - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 20
Altijd: 1,508
