Ga door naar hoofdinhoud
Sony SRS-X3 Battery Replacement
Wat je nodig hebt
  1. Sony SRS-X3 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the 6 philips head screws using the PH1 bit.
  2. Sony SRS-X3 Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the 3 philips head screws holding in the green circuit board
  3. Sony SRS-X3 Battery Replacement: stap 3, afbeelding 1 van 1
    • Unclip the battery pack and replace it with another one.
Conclusie
6 andere personen hebben deze handleiding voltooid.
3 opmerkingen
Can you give the battery # on this please
Dan Clark - Antwoord
Good instructions. I had one problem when removing the green circuit card. The ribbon cable came out. On mine there was a small black retention bar that I flipped open to allow the ribbon cable to reinsert, then I returned the retention bar back down to secure the ribbon cable in place. It worked fine after that.
Harpo - Antwoord
It would be nice if the article addressed the 6 rubber pads that cover the screws. There doesn't seem to be a way to remove them without damaging them, and you need them in order to use the speaker without it rattling and moving about from vibrations.
Peter Nosko - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 117
Altijd: 6,985
