Ga door naar hoofdinhoud
Sony SRS-X3 Auxiliary Port Replacement
Wat je nodig hebt
  1. Sony SRS-X3 Auxiliary Port  Replacement, Auxiliary Port Replacement: stap 1, afbeelding 1 van 1
    • Remove the 6 philips head screws using the screwdriver and the PH1 bit
  2. Sony SRS-X3 Auxiliary Port  Replacement: stap 2, afbeelding 1 van 1
    • Remove 5 philips head speakers holding in the battery and the green circuit board. 2 screws holding in the battery and 3 holding the circuit board.
  3. Sony SRS-X3 Auxiliary Port  Replacement: stap 3, afbeelding 1 van 1
    • Pick out the battery pack and the green circuit board so that you can see the ribbon wire and the wire running from the battery pack to the circuit board.
  4. Sony SRS-X3 Auxiliary Port  Replacement: stap 4, afbeelding 1 van 2 Sony SRS-X3 Auxiliary Port  Replacement: stap 4, afbeelding 2 van 2
    • Remove the ribbon wire and the connector coming from the battery pack to the circuit board.
    • These connectors will not easily pull out, so you might have to give them a tug. They aren't very fragile, so don't worry about shredding them.
    • After this step, simply insert a new circuit board and you're done! Reassemble the speaker and start jamming!
Conclusie
5 opmerkingen
Where did you buy the circuit board?
David Alvarez - Antwoord
bad repair doesn't actually show replaceing port just circuit board and no info where to buy one.
munchy 22 - Antwoord
Hi Andrew,
Can you tell me where I can purchase a replacement circuit board? I’m having trouble finding it online.
Part number is SONY 40BKB537U-CNF2G .
Thanks!
Julie Miller - Antwoord
Where can I buy the circuit board and if you want me to buy it from you fine but tell us or tell me
Thanks
Jose reyes - Antwoord
Donde puedo conseguir esas refacines
enriquereynahernandez423 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 16
Altijd: 1,818
