Ga door naar hoofdinhoud
Sony SLT Alpha-65V Viewfinder Replacement
Wat je nodig hebt
  1. Sony SLT Alpha-65V Viewfinder Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Unscrew the four 4.0 mm Phillips #00 screws with a on the base of the camera below the the scheme that separates the front and back panels.
    • Unscrew the 5.0 mm Phillips #00 screw on the bottom right of the camera.
    Vraag FixBot
    Voeg opmerking toe
  2. Sony SLT Alpha-65V Viewfinder Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the 4.0 mm Phillips #00 screw on bottom of the left side of the camera.
    • Unscrew the 5.0 mm Phillips #00 screw near the top of the left side of the camera.
    Vraag FixBot
    Voeg opmerking toe
  3. Sony SLT Alpha-65V Viewfinder Replacement: stap 3, afbeelding 1 van 1
    • Be careful when pulling the back panel away as it will still be connected to the body of the camera by two strips of film.
    • When unscrewing the 5.0 mm screw on the dial, make sure to hold onto the dial that becomes detached after taking out the screw.
    • Unscrew the two 4.0 mm Phillips #00 screw at the top of the camera by the eyepiece.
    • Unscrew the 5.0 mm Phillips #00 screw of the dial below the other two screws.
    • Once all the screws are removed, carefully use your hands to detach the back panel from the camera. Working around the edges can help as well.
    Vraag FixBot
    Voeg opmerking toe
  4. Sony SLT Alpha-65V Viewfinder Replacement: stap 4, afbeelding 1 van 3 Sony SLT Alpha-65V Viewfinder Replacement: stap 4, afbeelding 2 van 3 Sony SLT Alpha-65V Viewfinder Replacement: stap 4, afbeelding 3 van 3
    • Remove the two 4.0 mm Phillips #00 screws on the right of the camera that are located on the upper right side and under the "Remote" port flap.
    • Detach the right side panel with the remote and HDMI ports of the camera by gently pulling on the panel.
    Vraag FixBot
    Voeg opmerking toe
  5. Sony SLT Alpha-65V Viewfinder Replacement: stap 5, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • When the back panel is removed, be careful when moving the camera. There are parts inside the camera which now may come loose.
    • Use tweezers to remove the blue and orange ribbon connectors from their connection points pictured here.
    Vraag FixBot
    Voeg opmerking toe
  6. Sony SLT Alpha-65V Viewfinder Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • Remove the four 3.0 mm Phillips #00 screws.
    • Remove the 5.0 mm Phillips #00 screw.
    Vraag FixBot
    Voeg opmerking toe
  7. Sony SLT Alpha-65V Viewfinder Replacement: stap 7, afbeelding 1 van 3 Sony SLT Alpha-65V Viewfinder Replacement: stap 7, afbeelding 2 van 3 Sony SLT Alpha-65V Viewfinder Replacement: stap 7, afbeelding 3 van 3
    • Don't forget to close these switches and lock the film back into place when reassembling the camera.
    • Use your finger to flip the switch that holds the dual ribbon connector in place.
    • Gently use tweezers to disconnect the dual ribbon connector and the thin blue ribbon connector to the right of it from the circuit board.
    Vraag FixBot
    Voeg opmerking toe
  8. Sony SLT Alpha-65V Viewfinder Replacement: stap 8, afbeelding 1 van 3 Sony SLT Alpha-65V Viewfinder Replacement: stap 8, afbeelding 2 van 3 Sony SLT Alpha-65V Viewfinder Replacement: stap 8, afbeelding 3 van 3
    • Use tweezers to disconnect the blue, gold, and brown ribbon connectors near the top of the camera.
    Vraag FixBot
    Voeg opmerking toe
  9. Sony SLT Alpha-65V Viewfinder Replacement: stap 9, afbeelding 1 van 2 Sony SLT Alpha-65V Viewfinder Replacement: stap 9, afbeelding 2 van 2
    • Use a plastic opening tool to pop open the connector holding the next ribbon to the circuit board.
    • Use tweezers to disconnect the ribbon.
    Vraag FixBot
    Voeg opmerking toe
  10. Sony SLT Alpha-65V Viewfinder Replacement: stap 10, afbeelding 1 van 1
    • Use tweezers to unplug the blue adapter located at the top right of the circuit board.
    Vraag FixBot
    Voeg opmerking toe
  11. Sony SLT Alpha-65V Viewfinder Replacement: stap 11, afbeelding 1 van 1
    • Use either plastic opening tools or tweezers to unplug the white adapter located on the right side of the circuit board.
    Vraag FixBot
    Voeg opmerking toe
  12. Sony SLT Alpha-65V Viewfinder Replacement: stap 12, afbeelding 1 van 1
    • The circuit board will still be connected to the body of the camera by two pairs of cords.
    • Gently lift the circuit board away from the camera and turn it over.
    • Use tweezers to disconnect the final two plugs and completely remove the circuit board from the camera.
    Vraag FixBot
    Voeg opmerking toe
  13. Sony SLT Alpha-65V Viewfinder Replacement, Viewfinder: stap 13, afbeelding 1 van 3 Sony SLT Alpha-65V Viewfinder Replacement, Viewfinder: stap 13, afbeelding 2 van 3 Sony SLT Alpha-65V Viewfinder Replacement, Viewfinder: stap 13, afbeelding 3 van 3
    • The rotating dial on the right side of the eyepiece sensor is loosely connected and may fall out when removing the sensor.
    • Gently remove the eyepiece sensor from the viewfinder.
    Vraag FixBot
    Voeg opmerking toe
  14. Sony SLT Alpha-65V Viewfinder Replacement: stap 14, afbeelding 1 van 2 Sony SLT Alpha-65V Viewfinder Replacement: stap 14, afbeelding 2 van 2
    • The viewfinder will pop out of its slot.
    • Gently remove the viewfinder from the camera.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Zhengjun Jiang
140 Reputatie
1 Handleiding geschreven
Cal Poly, Team 14-11, Amido Spring 2015 Lid van Cal Poly, Team 14-11, Amido Spring 2015
CPSU-AMIDO-S15S14G11
4 Leden
13 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 57
Altijd: 2,058
