Inleiding
This guide will show you how to disconnect and remove the main circuit board of the Alpha 65 camera. This requires using a Phillips #00 screwdriver, plastic opening tool, and tweezers. Be sure to keep track of all screws and parts removed from the camera.
Wat je nodig hebt
Remove the two 4.0 mm Phillips #00 screws on the base of the camera.
Remove the 3.0 mm Phillips #00 screw on the hinge of the screen.
Unscrew the four 4.0 mm Phillips #00 screws with a on the base of the camera below the the scheme that separates the front and back panels.
Unscrew the 5.0 mm Phillips #00 screw on the bottom right of the camera.
Unscrew the two 4.0 mm Phillips #00 screw at the top of the camera by the eyepiece.
Unscrew the 5.0 mm Phillips #00 screw of the dial below the other two screws.
Once all the screws are removed, carefully use your hands to detach the back panel from the camera. Working around the edges can help as well.
Remove the four 3.0 mm Phillips #00 screws.
Remove the 5.0 mm Phillips #00 screw.
12 andere personen hebben deze handleiding voltooid.
5Gids Commentaar
I posted this link to a "Can't read SD card problem" below. On most SLTmodels apparently the SD card reader is part of the main circuit, and my local repair shop wanted $160 for labor (!) to swap out the part:
does anyone know if replacing the motherboard would fix a fried aperture lever control motor?
Thank you for all these Fixit helps. I am missing the replacement of the shutter motor. This is the most important repair in my eyes.
