Inleiding
This guide will teach you how to replace the flash capacitor of the Sony SLT Alpha -G5V camera. When taking off the orange circuit ribbon, it is easiest to start with lifting the small hole in the ribbon out of its connecting piece first. The capacitor itself will be soldered into the camera and the entire part must be replaced.
Wat je nodig hebt
Unscrew the four 4.0 mm Phillips #00 screws with a on the base of the camera below the the scheme that separates the front and back panels.
Unscrew the 5.0 mm Phillips #00 screw on the bottom right of the camera.
Unscrew the two 4.0 mm Phillips #00 screw at the top of the camera by the eyepiece.
Unscrew the 5.0 mm Phillips #00 screw of the dial below the other two screws.
Once all the screws are removed, carefully use your hands to detach the back panel from the camera. Working around the edges can help as well.
Remove the four 3.0 mm Phillips #00 screws.
Remove the 5.0 mm Phillips #00 screw.
Remove the 5.0 mm Phillips #00 screw on the right side of the flash capacitor.
5 andere personen hebben deze handleiding voltooid.
1Gids Commentaar
This is a welcome and well-illustrated guide. However, I don't necessarily agree that it qualifies as "easy". Also, and it seems to me this is very important, capacitors can maintain a significant electric charge for extended periods even when the battery has been removed and the camera is "off". The capacitor should be discharged before attempting to effect a repair. Finally, if one is experienced with soldering, the capacitor may be successfully replaced at very little cast (for the capacitor), thereby obviating the need to purchase the entire board.
