Ga door naar hoofdinhoud
Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement
Wat je nodig hebt
  1. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
  2. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: stap 2, afbeelding 1 van 1
    • Slide the back cover off by pushing it to the left, away from the side that held the screws.
    • Remove the cover.
  3. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: stap 3, afbeelding 1 van 1
    • This is what the device should look like once the back cover panel has been removed.
  4. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement, Battery: stap 4, afbeelding 1 van 1
    • Once the back cover has been removed locate the battery in the bottom right corner of the device.
    • Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
  5. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: stap 5, afbeelding 1 van 1
    • Use the flat end of the spudger to pry the battery out of its holder. There may be glue holding it in place.
  6. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement, Inner Casing: stap 6, afbeelding 1 van 1
    • Using a screwdriver remove the four 1.4 mm screws that are holding the black plastic casing in place.
  7. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: stap 7, afbeelding 1 van 1
    • Pry open the black casing to access the screw that is holding down the battery holder.
    • Remove the one 1.4 mm screw that is holding down the battery holder located under black casing.
    • Lift the black inner casing and the battery holder out of the device.
    • The battery holder and the black inner casing are connected by a thin strip of copper. There may be glue holding the black inner casing in place.
  8. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement, Power Button: stap 8, afbeelding 1 van 1
    • Remove the stylus from the device.
  9. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: stap 9, afbeelding 1 van 3 Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: stap 9, afbeelding 2 van 3 Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: stap 9, afbeelding 3 van 3
    • Using the Phillips screwdriver remove the 1.4 mm screw from the top panel.
    • Using the same screwdriver, remove the 1.4 mm screw from the back of the device.
    • Pry apart off the top panel of the device.
  10. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement, SD and Pro Duo Memory Cards Holder: stap 10, afbeelding 1 van 1
    • Using a Phillips head screwdriver, remove the three 1.4 mm screws located on the memory card holder.
  11. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: stap 11, afbeelding 1 van 1
    • Using the flat end of the spudger, pry open the brown flap that connects the cardholder to the motherboard.
  12. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: stap 12, afbeelding 1 van 2 Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: stap 12, afbeelding 2 van 2
    • Pull the orange strip out of the opened brown flap.
    • Remove the memory card holder.
Conclusie
Zachary Jeffers
412 Reputatie
4 handleidingen geschreven
Clemson, Team 1-4, Benson Fall 2014 Lid van Clemson, Team 1-4, Benson Fall 2014
CLEM-BENSON-F14S1G4
4 Leden
22 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 283
