Ga door naar hoofdinhoud
Sony Reader Touch Edition PRS-600 Battery Replacement
Wat je nodig hebt
    1. Sony Reader Touch Edition PRS-600 Battery Replacement, Back Panel: stap 1, afbeelding 1 van 1
      • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony Reader Touch Edition PRS-600 Battery Replacement: stap 2, afbeelding 1 van 1
      • Slide the back cover off by pushing it to the left, away from the side that held the screws.
      • Remove the cover.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony Reader Touch Edition PRS-600 Battery Replacement: stap 3, afbeelding 1 van 1
      • This is what the device should look like once the back cover panel has been removed.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony Reader Touch Edition PRS-600 Battery Replacement, Battery: stap 4, afbeelding 1 van 1
      • Once the back cover has been removed locate the battery in the bottom right corner of the device.
      • Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony Reader Touch Edition PRS-600 Battery Replacement: stap 5, afbeelding 1 van 1
      • Use the flat end of the spudger to pry the battery out of its holder. There may be glue holding it in place.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
9 andere personen hebben deze handleiding voltooid.
Terrika Ngobili
873 Reputatie
7 handleidingen geschreven
Clemson, Team 1-4, Benson Fall 2014 Lid van Clemson, Team 1-4, Benson Fall 2014
CLEM-BENSON-F14S1G4
4 Leden
77 handleidingen geschreven
2Gids Commentaar
It works great - thanks very much for this guide!
kitimatwoz - Antwoord Deel
where can i buy the battery for replacement ?? what battery is ? Answer me pls on: edgarjacob16@gmail.com
Edgar Jacob - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 81
Altijd: 6,239
