Ga door naar hoofdinhoud
Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement
Wat je nodig hebt
  1. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement, Sony Radio Model CFD S05 Prerequisite steps Replacement: stap 1, afbeelding 1 van 1
    • Unscrew the screws on the top of the radio.
  2. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: stap 2, afbeelding 1 van 2 Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: stap 2, afbeelding 2 van 2
    • Open the CD and cassette doors and remove the screws in the compartments.
    • To open the CD door push on the bottom left corner of the CD door. To open the cassette door push the button that is to the left of the pause button.
  3. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: stap 3, afbeelding 1 van 1
    • Flip the radio upside down and remove the battery cover. Unscrew the one screw below the batteries.
  4. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: stap 4, afbeelding 1 van 1
    • Remove the top of the radio enough to access the wires for removal.
    • Do not forcefully remove the whole top piece of the radio! There will be wires connected to the top cover and circuit board.
  5. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: stap 5, afbeelding 1 van 1
    • Remove all of the wires that are connected to both the circuit board and the underside of the top of the radio by pulling them where they are connected
    • This should include three sets of red and white wires, one set of white wires, one set of black wires, and two ribbon wires. Some cannot be disconnected from the top piece of the radio. Disconnect these plugs from the circuit board.
  6. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement, Belt for the Tape Motor: stap 6, afbeelding 1 van 1
    • Locate the motor of the radio on the underside of the top of the radio.
  7. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: stap 7, afbeelding 1 van 1
    • Unscrew the screw holding the motor to the top of the radio.
  8. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: stap 8, afbeelding 1 van 1
    • Lift up the motor.
    • Don't lift too high because the motor stand will break.
  9. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: stap 9, afbeelding 1 van 1
    • Unhook the larger band from under the motor and remove it.
  10. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: stap 10, afbeelding 1 van 1
    • Replace the band by hooking it beneath the motor.
  11. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: stap 11, afbeelding 1 van 1
    • Push the motor back down and screw it into place.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Ian Nussman
959 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2013 Lid van UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S2G5
2 Leden
Één opmerking
I'm worried about removing wires. How do you put them back? Doesn't that take some kind of special equipment/glue?
Carolyn Farley - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 41
Altijd: 5,083
