Ga door naar hoofdinhoud
Sony RDR HX750 HX950 Disassembly
Wat je nodig hebt
  1. Sony RDR HX750 HX950 Disassembly, Remove cover: stap 1, afbeelding 1 van 3 Sony RDR HX750 HX950 Disassembly, Remove cover: stap 1, afbeelding 2 van 3 Sony RDR HX750 HX950 Disassembly, Remove cover: stap 1, afbeelding 3 van 3
    • Remove the screws from the back and sides of the top cover.
  2. Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: stap 2, afbeelding 1 van 3 Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: stap 2, afbeelding 2 van 3 Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: stap 2, afbeelding 3 van 3
    • Remove the four screws that secure the hard drive mounting bracket to the bottom of the unit.
    • Unplug the two cables from the rear of the hard drive.
    • Remove the four screws from the bottom of the hard drive mounting bracket.
  3. Sony RDR HX750 HX950 Disassembly, Remove DVD player: stap 3, afbeelding 1 van 3 Sony RDR HX750 HX950 Disassembly, Remove DVD player: stap 3, afbeelding 2 van 3 Sony RDR HX750 HX950 Disassembly, Remove DVD player: stap 3, afbeelding 3 van 3
    • Remove the screws from the DVD cover
    • Remove the screws from the plastic cable holder
  4. Sony RDR HX750 HX950 Disassembly, Remove front Panel: stap 4, afbeelding 1 van 3 Sony RDR HX750 HX950 Disassembly, Remove front Panel: stap 4, afbeelding 2 van 3 Sony RDR HX750 HX950 Disassembly, Remove front Panel: stap 4, afbeelding 3 van 3
    • Insert the paper under each "click" to remove the front panel.
    • Once each "click" is loose, push the front panel gently.
    • The table of the compact disk has a little plastic piece in front that goes up to come out with a "click"
  5. Sony RDR HX750 HX950 Disassembly, Remove  DVD block: stap 5, afbeelding 1 van 3 Sony RDR HX750 HX950 Disassembly, Remove  DVD block: stap 5, afbeelding 2 van 3 Sony RDR HX750 HX950 Disassembly, Remove  DVD block: stap 5, afbeelding 3 van 3
    • Unplug the cables show in photo.
    • Disconnect the cable hidden on the side.
    • Remove the piece on the cd reader
  6. Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: stap 6, afbeelding 1 van 3 Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: stap 6, afbeelding 2 van 3 Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: stap 6, afbeelding 3 van 3
    • Under the DVD block, remove the screws as shown.
    • Remove the screws on the board.
    • Now the laser can be accessed.
  7. Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: stap 7, afbeelding 1 van 3 Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: stap 7, afbeelding 2 van 3 Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: stap 7, afbeelding 3 van 3
    • Inserir instruções aqui.
Conclusie
To open this dvd recorder folow this tutorial
Cafony
687 Reputatie
4 handleidingen geschreven
Één opmerking
Hello,HX950 work only with hdd 250Gb,or another,with 500 or 1000Gb ???
Cornelus - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 44
Altijd: 5,465
