Ga door naar hoofdinhoud
Sony Pulse Elite Edition Headband Replacement
Wat je nodig hebt
  1. Sony Pulse Elite Edition Headband Replacement, Remove Headband Screws: stap 1, afbeelding 1 van 2 Sony Pulse Elite Edition Headband Replacement, Remove Headband Screws: stap 1, afbeelding 2 van 2
    • Remove the two 5mm Phillips #00 screws from each side of the headband connected to the metal track.
  2. Sony Pulse Elite Edition Headband Replacement, Remove Plastic Screw Bracket: stap 2, afbeelding 1 van 2 Sony Pulse Elite Edition Headband Replacement, Remove Plastic Screw Bracket: stap 2, afbeelding 2 van 2
    • After removing the screws, push the small plastic protector on one of the sides towards the speaker closest to it.
    • After the protector has slid out of its slot, pull it away from the bar until it pops off the track.
    • Repeat this process for small plastic protector on the other side.
  3. Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: stap 3, afbeelding 1 van 3 Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: stap 3, afbeelding 2 van 3 Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: stap 3, afbeelding 3 van 3
    • Using your thumb, slide the cushion on one of the two adjusting rails toward the closest speaker.
    • Once enough of the cushion has separated from the rail, pull the rest of it off.
    • Repeat the process for the other rail.
  4. Sony Pulse Elite Edition Headband Replacement, Slide Headband Off Rails: stap 4, afbeelding 1 van 1
    • Gently pull the headband away from one of the speaker component groups, as if expanding it. Continue pulling until it is completely off the track.
    • Remove the white and red wires from inside the headband.
    • Be sure to keep the two speakers close together since they are still linked via the speaker wires.
    • Repeat this process for the other side.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Chris Echter
865 Reputatie
4 handleidingen geschreven
Clemson, Team 14-2, Shirley Spring 2015 Lid van Clemson, Team 14-2, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G2
5 Leden
12 handleidingen geschreven
Één opmerking
have any experience with the sony gold headset, i got two of them that broke in the same spot, right at the hinge
Rich Gallagher - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 96
Altijd: 5,864
