Ga door naar hoofdinhoud
Sony PlayStation Camera Microphone Array Replacement
Wat je nodig hebt
  1. Sony PlayStation Camera Microphone Array Replacement, Microphone Array: stap 1, afbeelding 1 van 2 Sony PlayStation Camera Microphone Array Replacement, Microphone Array: stap 1, afbeelding 2 van 2
    • Separate the camera from the camera stand to gain access to the bottom of the camera.
  2. Sony PlayStation Camera Microphone Array Replacement: stap 2, afbeelding 1 van 2 Sony PlayStation Camera Microphone Array Replacement: stap 2, afbeelding 2 van 2
    • With the PH000 sized screwdriver, remove the two 6.5mm Phillips #000 screws located under the stand connection point, where the cable enters the case.
  3. Sony PlayStation Camera Microphone Array Replacement: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Using tweezers, remove the cap holding the cable grommet in place.
  4. Sony PlayStation Camera Microphone Array Replacement: stap 4, afbeelding 1 van 1
    • Using the tweezers, remove both poly-carbonate lens coverplates.
    • Lift the coverplates slowly, to ensure they do not crack, or break.
  5. Sony PlayStation Camera Microphone Array Replacement: stap 5, afbeelding 1 van 2 Sony PlayStation Camera Microphone Array Replacement: stap 5, afbeelding 2 van 2
    • Using the PH0 sized screwdriver, remove two 3.2mm Phillips #0 screws, located under the coverplates.
  6. Sony PlayStation Camera Microphone Array Replacement: stap 6, afbeelding 1 van 1
    • Using extreme care, separate the front of the case, from the back with a metal spudger, or pry tool. The case will scratch easily.
    • The case joints can be hard to spot. They appear as a very fine line in the plastic. Start with light pressure until the seam parts, allowing the pry tool to work.
  7. Sony PlayStation Camera Microphone Array Replacement: stap 7, afbeelding 1 van 2 Sony PlayStation Camera Microphone Array Replacement: stap 7, afbeelding 2 van 2
    • Using the PH0 sized screwdriver, remove the four 4.5mm Phillips #0 screws securing the circuit assembly to the device housing.
  8. Sony PlayStation Camera Microphone Array Replacement: stap 8, afbeelding 1 van 3 Sony PlayStation Camera Microphone Array Replacement: stap 8, afbeelding 2 van 3 Sony PlayStation Camera Microphone Array Replacement: stap 8, afbeelding 3 van 3
    • Lift the motherboard and frame from the plastic housing.
    • Disconnect the camera cable from the motherboard.
  9. Sony PlayStation Camera Microphone Array Replacement: stap 9, afbeelding 1 van 2 Sony PlayStation Camera Microphone Array Replacement: stap 9, afbeelding 2 van 2
    • Using the PH0 sized screwdriver, remove the six 4.2mm Phillips #0 screws securing the motherboard to the metal frame.
  10. Sony PlayStation Camera Microphone Array Replacement: stap 10, afbeelding 1 van 2 Sony PlayStation Camera Microphone Array Replacement: stap 10, afbeelding 2 van 2
    • Using a plastic opening tool, disconnect the microphone array connector from the motherboard.
  11. Sony PlayStation Camera Microphone Array Replacement: stap 11, afbeelding 1 van 3 Sony PlayStation Camera Microphone Array Replacement: stap 11, afbeelding 2 van 3 Sony PlayStation Camera Microphone Array Replacement: stap 11, afbeelding 3 van 3
    • Using fine point tweezers, grab hold of each microphone, one at a time, and lift from the plastic frame.
    • Using care to not damage the wires, remove microphone array from the retaining tabs on the plastic frame.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Joshua Gates
268 Reputatie
2 handleidingen geschreven
USF Tampa, Team 5-5, Passmore Spring 2017 Lid van USF Tampa, Team 5-5, Passmore Spring 2017
USFT-PASSMORE-S17S5G5
3 Leden
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 89
Altijd: 7,670
