Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the base by pushing in the button and sliding out the unit.
Remove USB port cover from back plate with a metal spudger.
With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
Remove back plate with a plastic opening tool by slowing prying around the entire plate.
Once separated the plate easily lifts off.
With the Phillips #01 screwdriver, remove the four 5 mm length x 7 mm head screws from the assembly (two for each side speaker).
Remove the plastic plate covering the speaker.
Lift the speaker out of its holding tray.
Remove the speaker by depressing the white tab on the speaker wire connector.
3 andere personen hebben deze handleiding voltooid.
Één opmerking
Speakers in this page are out of stock, do you think these will work? https://www.amazon.com/Speaker-Speakers-...
