Ga door naar hoofdinhoud
Sony PlayStation 3D Display Side Speakers Replacement
Wat je nodig hebt
  1. Sony PlayStation 3D Display Side Speakers Replacement, Rear Case: stap 1, afbeelding 1 van 2 Sony PlayStation 3D Display Side Speakers Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • Remove the base by pushing in the button and sliding out the unit.
  2. Sony PlayStation 3D Display Side Speakers Replacement: stap 2, afbeelding 1 van 3 Sony PlayStation 3D Display Side Speakers Replacement: stap 2, afbeelding 2 van 3 Sony PlayStation 3D Display Side Speakers Replacement: stap 2, afbeelding 3 van 3
    • Remove USB port cover from back plate with a metal spudger.
    • This will prevent the cover from falling under the back plate once it is removed.
  3. Sony PlayStation 3D Display Side Speakers Replacement: stap 3, afbeelding 1 van 2 Sony PlayStation 3D Display Side Speakers Replacement: stap 3, afbeelding 2 van 2
    • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
    • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
    • These screws have different threads and need to be kept separate.
  4. Sony PlayStation 3D Display Side Speakers Replacement: stap 4, afbeelding 1 van 3 Sony PlayStation 3D Display Side Speakers Replacement: stap 4, afbeelding 2 van 3 Sony PlayStation 3D Display Side Speakers Replacement: stap 4, afbeelding 3 van 3
    • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
    • Be gentle to avoid breaking the plastic clips which hold the plate.
    • Once separated the plate easily lifts off.
  5. Sony PlayStation 3D Display Side Speakers Replacement, Side Speakers: stap 5, afbeelding 1 van 3 Sony PlayStation 3D Display Side Speakers Replacement, Side Speakers: stap 5, afbeelding 2 van 3 Sony PlayStation 3D Display Side Speakers Replacement, Side Speakers: stap 5, afbeelding 3 van 3
    • With the Phillips #01 screwdriver, remove the four 5 mm length x 7 mm head screws from the assembly (two for each side speaker).
  6. Sony PlayStation 3D Display Side Speakers Replacement: stap 6, afbeelding 1 van 3 Sony PlayStation 3D Display Side Speakers Replacement: stap 6, afbeelding 2 van 3 Sony PlayStation 3D Display Side Speakers Replacement: stap 6, afbeelding 3 van 3
    • Remove the plastic plate covering the speaker.
    • When reassembling, make sure the arrow on the plastic plate is facing up.
    • Lift the speaker out of its holding tray.
  7. Sony PlayStation 3D Display Side Speakers Replacement: stap 7, afbeelding 1 van 2 Sony PlayStation 3D Display Side Speakers Replacement: stap 7, afbeelding 2 van 2
    • Remove the speaker by depressing the white tab on the speaker wire connector.
Conclusie
3 andere personen hebben deze handleiding voltooid.
viharim
200 Reputatie
1 Handleiding geschreven
Cal Poly, Team 12-16, Maness Fall 2015 Lid van Cal Poly, Team 12-16, Maness Fall 2015
CPSU-MANESS-F15S12G16
4 Leden
8 handleidingen geschreven
Één opmerking
Speakers in this page are out of stock, do you think these will work? https://www.amazon.com/Speaker-Speakers-...
Ferserk - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 26
Altijd: 2,605
