Ga door naar hoofdinhoud
Sony PlayStation 3D Display Power Port Replacement
Wat je nodig hebt
  1. Sony PlayStation 3D Display Power Port Replacement, Rear Case: stap 1, afbeelding 1 van 2 Sony PlayStation 3D Display Power Port Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • Remove the base by pushing in the button and sliding out the unit.
  2. Sony PlayStation 3D Display Power Port Replacement: stap 2, afbeelding 1 van 3 Sony PlayStation 3D Display Power Port Replacement: stap 2, afbeelding 2 van 3 Sony PlayStation 3D Display Power Port Replacement: stap 2, afbeelding 3 van 3
    • Remove USB port cover from back plate with a metal spudger.
    • This will prevent the cover from falling under the back plate once it is removed.
  3. Sony PlayStation 3D Display Power Port Replacement: stap 3, afbeelding 1 van 2 Sony PlayStation 3D Display Power Port Replacement: stap 3, afbeelding 2 van 2
    • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
    • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
    • These screws have different threads and need to be kept separate.
  4. Sony PlayStation 3D Display Power Port Replacement: stap 4, afbeelding 1 van 3 Sony PlayStation 3D Display Power Port Replacement: stap 4, afbeelding 2 van 3 Sony PlayStation 3D Display Power Port Replacement: stap 4, afbeelding 3 van 3
    • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
    • Be gentle to avoid breaking the plastic clips which hold the plate.
    • Once separated the plate easily lifts off.
  5. Sony PlayStation 3D Display Power Port Replacement, Power Port: stap 5, afbeelding 1 van 3 Sony PlayStation 3D Display Power Port Replacement, Power Port: stap 5, afbeelding 2 van 3 Sony PlayStation 3D Display Power Port Replacement, Power Port: stap 5, afbeelding 3 van 3
    • With the Phillips #02 screwdriver, remove the two 5mm length x 7mm head screws from the left and right side of the power port plate.
  6. Sony PlayStation 3D Display Power Port Replacement: stap 6, afbeelding 1 van 3 Sony PlayStation 3D Display Power Port Replacement: stap 6, afbeelding 2 van 3 Sony PlayStation 3D Display Power Port Replacement: stap 6, afbeelding 3 van 3
    • Remove the power port by depressing the white tab attached to the wires.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Logan Simon
234 Reputatie
1 Handleiding geschreven
Cal Poly, Team 12-16, Maness Fall 2015 Lid van Cal Poly, Team 12-16, Maness Fall 2015
CPSU-MANESS-F15S12G16
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 1,564
