Ga door naar hoofdinhoud
Sony PS-LX300USB Motor Replacement
Wat je nodig hebt
  1. Sony PS-LX300USB Motor Replacement, Dust Cover: stap 1, afbeelding 1 van 1
    • Turn the turntable around so that the back side is visible.
  2. Sony PS-LX300USB Motor Replacement: stap 2, afbeelding 1 van 2 Sony PS-LX300USB Motor Replacement: stap 2, afbeelding 2 van 2
    • Begin by releasing the left latch. Apply downward pressure to the square, black button using a flathead screw driver.
    • Once the latch is released, lift upward.
    • Use your left hand to hold the left side of the dust cover above the latch. This ensures the latch does not reconnect.
  3. Sony PS-LX300USB Motor Replacement: stap 3, afbeelding 1 van 1
    • Use a flat head screw driver to apply pressure to the black square button on the right side.
  4. Sony PS-LX300USB Motor Replacement: stap 4, afbeelding 1 van 2 Sony PS-LX300USB Motor Replacement: stap 4, afbeelding 2 van 2
    • Once both the right and left buttons are released, pull the dust cover upwards.
    • The dust cover is now disconnected and ready for replacement.
  5. Sony PS-LX300USB Motor Replacement, Drive Belt: stap 5, afbeelding 1 van 2 Sony PS-LX300USB Motor Replacement, Drive Belt: stap 5, afbeelding 2 van 2
    • Lift the rubber mat, and put it to the side. It should be easy to remove, because it simply rests on a metal platter without anything securing it down.
  6. Sony PS-LX300USB Motor Replacement: stap 6, afbeelding 1 van 1
    • Turn the platter so that the motor pulley can be seen through one of the two outer holes in the platter.
    • If the drive belt is hooked around the motor pulley, unhook it.
    • When reassembling to device, don't forget to hook the new drive belt to the motor pulley.
  7. Sony PS-LX300USB Motor Replacement: stap 7, afbeelding 1 van 1
    • Grasping the platter by its two inner holes, lift it upwards.
    • Removing the platter may take a small amount of force. If the pulley is unhooked and the tone arm is safely to the side, don’t fear using a small amount of force in lifting the platter.
    • If you haven’t yet unhooked the drive belt, the motor pulley and the belt could sustain damage.
  8. Sony PS-LX300USB Motor Replacement: stap 8, afbeelding 1 van 2 Sony PS-LX300USB Motor Replacement: stap 8, afbeelding 2 van 2
    • Peel the drive belt from the inner ridge of the metal platter and put it to the side.
    • Sometimes, the drive belt can fall off the platter during deconstruction. If this is the case, simply take it out of the device wherever it is.
  9. Sony PS-LX300USB Motor Replacement, Motor: stap 9, afbeelding 1 van 2 Sony PS-LX300USB Motor Replacement, Motor: stap 9, afbeelding 2 van 2
    • Use a PH2 screwdriver to remove the 8 screws from the bottom cover.
    • Now lift the bottom cover to remove it.
  10. Sony PS-LX300USB Motor Replacement: stap 10, afbeelding 1 van 1
    • The motor is in the right upper corner area of the turntable, shown in the red square.
  11. Sony PS-LX300USB Motor Replacement: stap 11, afbeelding 1 van 1
    • Using a solder iron, carefully desolder the wires that are connected to the old motor to be able to remove it. Making sure to pay close attention where each wire is connected.
    • From left to right: Black is all the way to the left. Red is next. White is third. Yellow is all the way to the right.
    • When reassembling, do not forget to solder in the wires in their previous places.
  12. Sony PS-LX300USB Motor Replacement: stap 12, afbeelding 1 van 1
    • Remove the old motor by turning it counterclockwise, freeing it from its position.
    • When reassembling, place the new motor in by aligning the two screws and turning the motor clockwise to secure it.
Conclusie
Christian Fuentes
116 Reputatie
1 Handleiding geschreven
Cal Poly, Team S8-G3, Banghart Fall 2017 Lid van Cal Poly, Team S8-G3, Banghart Fall 2017
CPSU-BANGHART-F17S8G3
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 39
Altijd: 3,364
