Ga door naar hoofdinhoud
Sony NWZ-E473 Battery Replacement
Wat je nodig hebt
  1. Sony NWZ-E473 Battery Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
  2. Sony NWZ-E473 Battery Replacement: stap 2, afbeelding 1 van 1
    • Use a plastic opening tool to loosen the bottom portion of device.
  3. Sony NWZ-E473 Battery Replacement: stap 3, afbeelding 1 van 1
    • Use a plastic opening tool to loosen the top panel of the device.
  4. Sony NWZ-E473 Battery Replacement: stap 4, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws located on the portion under the top panel of the device.
  5. Sony NWZ-E473 Battery Replacement: stap 5, afbeelding 1 van 3 Sony NWZ-E473 Battery Replacement: stap 5, afbeelding 2 van 3 Sony NWZ-E473 Battery Replacement: stap 5, afbeelding 3 van 3
    • Remove the back plate from the device.
  6. Sony NWZ-E473 Battery Replacement, Battery: stap 6, afbeelding 1 van 2 Sony NWZ-E473 Battery Replacement, Battery: stap 6, afbeelding 2 van 2
    • Peel back the layer of tape along with the processor, which is located just below the battery, using the tweezers and the spudger.
  7. Sony NWZ-E473 Battery Replacement: stap 7, afbeelding 1 van 2 Sony NWZ-E473 Battery Replacement: stap 7, afbeelding 2 van 2
    • Slide a prying tool underneath the top portion of the battery and lift it from the case.
  8. Sony NWZ-E473 Battery Replacement: stap 8, afbeelding 1 van 1
    • Remove the stickers from the battery terminals, which are on the underside of the battery.
  9. Sony NWZ-E473 Battery Replacement: stap 9, afbeelding 1 van 1
    • Use a soldering iron to remove the wires from the red and the black terminals.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Matthew Hintz
327 Reputatie
3 handleidingen geschreven
USF Tampa, Team 17-6, Watkins Winter 2015 Lid van USF Tampa, Team 17-6, Watkins Winter 2015
USFT-WATKINS-W15S17G6
4 Leden
5 handleidingen geschreven
2 opmerkingen
Hi their I have a Sony nwz-e355 walkman I want to replace the battery in it cause I thinks it's done I see u do a replacement for the e473 wondering if u have e355 batteries or will this e473 battery work in my walkman both need to be soildered in any feed back would help
Derek Hebert - Antwoord
I have the same model. I have 2 of them purchased years ago from Ubid.com. A very cool device. SONY ought to service them when the batteries fade…
guy lewit -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 19
Altijd: 9,473
