Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
Use a plastic opening tool to loosen the bottom portion of device.
Use a plastic opening tool to loosen the top panel of the device.
Use a Phillips #00 screwdriver to remove the two 3 mm screws located on the portion under the top panel of the device.
Unscrew one 2.5 mm screw using a Phillips #00 screwdriver on bottom right portion of device located near audio jack.
Disconnect the headphone jack connection from the motherboard using any tool to remove black audio piece that needs to be replaced.
Één andere persoon heeft deze handleiding voltooid.
