Ga door naar hoofdinhoud
Sony NEX-5R Top Panel Replacement
Wat je nodig hebt
  1. Sony NEX-5R Top Panel Replacement, Front Case: stap 1, afbeelding 1 van 2 Sony NEX-5R Top Panel Replacement, Front Case: stap 1, afbeelding 2 van 2
    • Open the battery pack door by moving the slider to "OPEN".
    • Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
  2. Sony NEX-5R Top Panel Replacement: stap 2, afbeelding 1 van 1
    • Remove the 3.25 mm exterior screw with a Phillips screwdriver.
  3. Sony NEX-5R Top Panel Replacement: stap 3, afbeelding 1 van 2 Sony NEX-5R Top Panel Replacement: stap 3, afbeelding 2 van 2
    • Use the spudger to raise the corner of the case from the camera.
    • One component of the front case should now be separate from the camera.
  4. Sony NEX-5R Top Panel Replacement, Rear Case: stap 4, afbeelding 1 van 1
    • Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
  5. Sony NEX-5R Top Panel Replacement: stap 5, afbeelding 1 van 1
    • Open the HDMI port, and remove the the two (3.5 mm) Phillips screws exposed on that side.
  6. Sony NEX-5R Top Panel Replacement: stap 6, afbeelding 1 van 1
    • Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
  7. Sony NEX-5R Top Panel Replacement: stap 7, afbeelding 1 van 1
    • Looking at the bottom of the camera, use the spudger to lift the rear case away from the camera body.
  8. Sony NEX-5R Top Panel Replacement: stap 8, afbeelding 1 van 2 Sony NEX-5R Top Panel Replacement: stap 8, afbeelding 2 van 2
    • Using the spudger again, carefully pry from the top of the camera to remove the back frame.
    • The back frame is fragile, so use the spudger gently.
  9. Sony NEX-5R Top Panel Replacement: stap 9, afbeelding 1 van 1
    • The back case should now be removed and look like this.
  10. Sony NEX-5R Top Panel Replacement, Top Panel: stap 10, afbeelding 1 van 1
    • Remove the 3.5mm phillips head screw underneath the flash port
  11. Sony NEX-5R Top Panel Replacement: stap 11, afbeelding 1 van 1
    • Remove the 3.5mm phillips head screw on the top left of the camera.
  12. Sony NEX-5R Top Panel Replacement: stap 12, afbeelding 1 van 1
    • Use the spudger tool to go around the seam of the top panel. The top should easily lift off.
  13. Sony NEX-5R Top Panel Replacement: stap 13, afbeelding 1 van 2 Sony NEX-5R Top Panel Replacement: stap 13, afbeelding 2 van 2
    • This is what the camera and top panel should look like after you have completed the guide
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Steven Fronczak
322 Reputatie
1 Handleiding geschreven
Cal Poly, Team 8-9, Regan Spring 2014 Lid van Cal Poly, Team 8-9, Regan Spring 2014
CPSU-REGAN-S14S8G9
4 Leden
14 handleidingen geschreven
Één opmerking
Hey Steven! This is all wrong! That's not the wright order: actually the top panel is the first part that can be removed, you don't need to tear down the rear panel and the front handgrip.. (it also may cause the damage of the rear panel!).
So, in order to remove the top panel just follow this order:
STEP 2
STEP 5 (Just the upper screw (not that one between HDMI and USB port)
STEP 6 (Just the two 4mm screws)
STEP 10
STEP 12
Its a lot easier ;)
Daniele
Daniele Fior - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 8
Altijd: 2,390
