Ga door naar hoofdinhoud
Sony NEX-5R Main Navigation Button Replacement
Wat je nodig hebt
  1. Sony NEX-5R Main Navigation Button Replacement, Rear Case: stap 1, afbeelding 1 van 1
    • Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
  2. Sony NEX-5R Main Navigation Button Replacement: stap 2, afbeelding 1 van 1
    • Open the HDMI port, and remove the the two (3.5 mm) Phillips screws exposed on that side.
  3. Sony NEX-5R Main Navigation Button Replacement: stap 3, afbeelding 1 van 1
    • Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
  4. Sony NEX-5R Main Navigation Button Replacement: stap 4, afbeelding 1 van 1
    • Looking at the bottom of the camera, use the spudger to lift the rear case away from the camera body.
  5. Sony NEX-5R Main Navigation Button Replacement: stap 5, afbeelding 1 van 2 Sony NEX-5R Main Navigation Button Replacement: stap 5, afbeelding 2 van 2
    • Using the spudger again, carefully pry from the top of the camera to remove the back frame.
    • The back frame is fragile, so use the spudger gently.
  6. Sony NEX-5R Main Navigation Button Replacement: stap 6, afbeelding 1 van 1
    • The back case should now be removed and look like this.
  7. Sony NEX-5R Main Navigation Button Replacement, Main Navigation Button: stap 7, afbeelding 1 van 1
    • Use spudger to pull the lead out from its housing.
  8. Sony NEX-5R Main Navigation Button Replacement: stap 8, afbeelding 1 van 2 Sony NEX-5R Main Navigation Button Replacement: stap 8, afbeelding 2 van 2
    • Squeeze the lead with the tweezers and hold the lead teeth tightly with your fingers. Pull straight out to disconnect.
  9. Sony NEX-5R Main Navigation Button Replacement: stap 9, afbeelding 1 van 2 Sony NEX-5R Main Navigation Button Replacement: stap 9, afbeelding 2 van 2
    • The navigation button component should now be separate and able to be replaced with new component. The camera and navigation button should appear as shown.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Emily Trujillo
1.114 Reputatie
6 handleidingen geschreven
Cal Poly, Team 8-9, Regan Spring 2014 Lid van Cal Poly, Team 8-9, Regan Spring 2014
CPSU-REGAN-S14S8G9
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 21
Altijd: 3,758
