Inleiding
If your camera isn’t properly displaying images or if the images are distorted, your lens may be the source of the problem. It’s important to keep your camera lens clean so that the resulting images aren’t dirty or filled with junk. Refer to this guide if the camera’s lens is not working or there is a problem with it!
Wat je nodig hebt
Rotate the shell of the base in the anti-clockwise direction so that you can detach it from the lens.
