Inleiding
This guide will walk you through the steps needed to safely replace the damaged LCD screen, ensuring that your camera looks and works as good as new. Whether you're a DIY enthusiast or just looking to save on repair costs, this step-by-step tutorial will help you complete the replacement process with minimal tools and effort. Let's get started on bringing your Sony MVC-FD200 back to life!
Wat je nodig hebt
Using your finger, slide the tab on the battery door up to release the battery latch.
Turn the camera so that the top is facing down towards the table.
Using the Phillips #00 screwdriver, remove all 2.0 mm screws with the arrows facing towards them.
Detach the ribbon cable that connects the two halves of the device to split them apart.
Gently pry up the black plastic tab to slide out the ribbon cables.
1Gids Commentaar
I have a Mavica FD71, will this work about the same? (Pixels in the middle of the screen have started to die) I’ve been looking, but I can’t find a replacement lcd panel for my model, do the Mavica FD2000 and the FD71 use the same lcd panel?
