Ga door naar hoofdinhoud
Sony M-430 Microcassette-Corder Speaker Replacement
Wat je nodig hebt
  1. Sony M-430 Microcassette-Corder Speaker Replacement, Battery: stap 1, afbeelding 1 van 1
    • Find the arrow on the battery cover on the back of the device.
    • While pressing down on the arrow, slide the cover towards the bottom of the recorder until it clicks.
  2. Sony M-430 Microcassette-Corder Speaker Replacement: stap 2, afbeelding 1 van 2 Sony M-430 Microcassette-Corder Speaker Replacement: stap 2, afbeelding 2 van 2
    • Lift the cover and remove the batteries.
  3. Sony M-430 Microcassette-Corder Speaker Replacement, Back Cover: stap 3, afbeelding 1 van 2 Sony M-430 Microcassette-Corder Speaker Replacement, Back Cover: stap 3, afbeelding 2 van 2
    • Remove the battery cover by first tilting it so it is at a right angle with the rest of the device.
    • Next, twist it to the side as shown in the second picture. The lid should simply snap off.
    • Be careful not to apply too much force, as the lid may break.
  4. Sony M-430 Microcassette-Corder Speaker Replacement: stap 4, afbeelding 1 van 2 Sony M-430 Microcassette-Corder Speaker Replacement: stap 4, afbeelding 2 van 2
    • Use a #00 Phillips head screwdriver to remove the four (1.7x16 mm) screws from the back case.
    • Next, use the same screwdriver to unscrew the (1.7X5 mm) screw, which is located inside the battery compartment.
  5. Sony M-430 Microcassette-Corder Speaker Replacement: stap 5, afbeelding 1 van 1
    • Use a spudger to push in the two tabs located on the bottom of the device.
    • It works best to push the tabs at an upward angle (towards the top of the battery compartment)
    • It may take a decent amount of force in order to push in the tabs.
  6. Sony M-430 Microcassette-Corder Speaker Replacement: stap 6, afbeelding 1 van 1
    • With a firm grip on the larger half, remove the back cover by lifting first on the battery area.
    • The back cover should lift cleanly off.
  7. Sony M-430 Microcassette-Corder Speaker Replacement, Speaker: stap 7, afbeelding 1 van 1
    • The speaker is the large gold circular piece attached under where the batteries would normally be.
    • It is connected to the device with two black wires that run along one side of the motherboard, as shown on the top of the picture.
  8. Sony M-430 Microcassette-Corder Speaker Replacement: stap 8, afbeelding 1 van 2 Sony M-430 Microcassette-Corder Speaker Replacement: stap 8, afbeelding 2 van 2
    • Depending on the replacement speaker you have, there are two places you can desolder the wire.
    • If your replacement speaker has a wire already attached to it, desolder the old wire from where it connects to the motherboard.
    • If the replacement speaker has no wire, desolder the old wire where it connects to the broken speaker.
  9. Sony M-430 Microcassette-Corder Speaker Replacement: stap 9, afbeelding 1 van 2 Sony M-430 Microcassette-Corder Speaker Replacement: stap 9, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Unscrew the 2 Phillips head screws (2x2.5 mm) around the edge of the speaker with a #00 Phillips screwdriver.
    • Use a pair of tweezers to remove the black tape on the speaker. Put the tape on the back of the new speaker.
  10. Sony M-430 Microcassette-Corder Speaker Replacement: stap 10, afbeelding 1 van 1
    • Now that the speaker is detached from the device, simply tilt the device over and let the speaker fall out.
Conclusie
Matt Teare
35 Reputatie
3 handleidingen geschreven
Cal Poly, Team 10-34, Amido Winter 2012 Lid van Cal Poly, Team 10-34, Amido Winter 2012
CPSU-AMIDO-W12S10G34
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 9
Altijd: 919
