Wat je nodig hebt
Find the arrow on the battery cover on the back of the device.
While pressing down on the arrow, slide the cover towards the bottom of the recorder until it clicks.
Remove the battery cover by first tilting it so it is at a right angle with the rest of the device.
Next, twist it to the side as shown in the second picture. The lid should simply snap off.
The speaker is the large gold circular piece attached under where the batteries would normally be.
It is connected to the device with two black wires that run along one side of the motherboard, as shown on the top of the picture.
Depending on the replacement speaker you have, there are two places you can desolder the wire.
If your replacement speaker has a wire already attached to it, desolder the old wire from where it connects to the motherboard.
If the replacement speaker has no wire, desolder the old wire where it connects to the broken speaker.
