Ga door naar hoofdinhoud
Sony M-430 Microcassette-Corder Mechanism Deck Replacement
Wat je nodig hebt
  1. Sony M-430 Microcassette-Corder Mechanism Deck Replacement, Cassette Lid: stap 1, afbeelding 1 van 3 Sony M-430 Microcassette-Corder Mechanism Deck Replacement, Cassette Lid: stap 1, afbeelding 2 van 3 Sony M-430 Microcassette-Corder Mechanism Deck Replacement, Cassette Lid: stap 1, afbeelding 3 van 3
    • Using a spudger, apply pressure towards the back corner of the cassette compartment to the plastic tab directly behind the gold cone.
    • Pushing the tab allows the hinge to be separated from the body of the device.
    • The third picture shows the what the tab looks like when the device is disassembled, and illustrates the direction to apply pressure.
  2. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: stap 2, afbeelding 1 van 2 Sony M-430 Microcassette-Corder Mechanism Deck Replacement: stap 2, afbeelding 2 van 2
    • Next, use a plastic opening tool to pull the metal latch towards the speaker.
    • The latch should be clear of the slot in the cassette lid.
    • Be careful not to bend the latch too far, as it may warp.
  3. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: stap 3, afbeelding 1 van 1
    • Carefully lift the cassette lid, making sure the tab and latch are free from connection.
  4. Sony M-430 Microcassette-Corder Mechanism Deck Replacement, Battery: stap 4, afbeelding 1 van 1
    • Find the arrow on the battery cover on the back of the device.
    • While pressing down on the arrow, slide the cover towards the bottom of the recorder until it clicks.
  5. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: stap 5, afbeelding 1 van 2 Sony M-430 Microcassette-Corder Mechanism Deck Replacement: stap 5, afbeelding 2 van 2
    • Lift the cover and remove the batteries.
  6. Sony M-430 Microcassette-Corder Mechanism Deck Replacement, Back Cover: stap 6, afbeelding 1 van 2 Sony M-430 Microcassette-Corder Mechanism Deck Replacement, Back Cover: stap 6, afbeelding 2 van 2
    • Remove the battery cover by first tilting it so it is at a right angle with the rest of the device.
    • Next, twist it to the side as shown in the second picture. The lid should simply snap off.
    • Be careful not to apply too much force, as the lid may break.
  7. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: stap 7, afbeelding 1 van 2 Sony M-430 Microcassette-Corder Mechanism Deck Replacement: stap 7, afbeelding 2 van 2
    • Use a #00 Phillips head screwdriver to remove the four (1.7x16 mm) screws from the back case.
    • Next, use the same screwdriver to unscrew the (1.7X5 mm) screw, which is located inside the battery compartment.
  8. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: stap 8, afbeelding 1 van 1
    • Use a spudger to push in the two tabs located on the bottom of the device.
    • It works best to push the tabs at an upward angle (towards the top of the battery compartment)
    • It may take a decent amount of force in order to push in the tabs.
    I didn’t push on the tabs, but put a spudger along the seem and the clips released with minimal force!
    RadioShack - Antwoord
  9. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: stap 9, afbeelding 1 van 1
    • With a firm grip on the larger half, remove the back cover by lifting first on the battery area.
    • The back cover should lift cleanly off.
  10. Sony M-430 Microcassette-Corder Mechanism Deck Replacement, Motherboard: stap 10, afbeelding 1 van 2 Sony M-430 Microcassette-Corder Mechanism Deck Replacement, Motherboard: stap 10, afbeelding 2 van 2
    • Using tweezers, pull upward on the black tape which secures the wires.
    • Removing this tape allows you to move the wires out of the way for the next step.
  11. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: stap 11, afbeelding 1 van 2 Sony M-430 Microcassette-Corder Mechanism Deck Replacement: stap 11, afbeelding 2 van 2
    • Desolder all wires connecting components to the motherboard.
    • Be careful to not melt the solder points together.
    • A red wire and a blue wire connect the motor to the motherboard.
    • Two black wires connect the speaker to the motherboard.
    • A red wire and a black wire connect the microphone to the motherboard.
  12. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: stap 12, afbeelding 1 van 1
    • After desoldering the microphone connections, pull the microphone straight out from the device and set aside.
    • Be careful not to tear the wires off of the microphone.
    • Removing the microphone gives you access to the green ribbon cable that connects to the mechanism deck.
  13. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: stap 13, afbeelding 1 van 2 Sony M-430 Microcassette-Corder Mechanism Deck Replacement: stap 13, afbeelding 2 van 2
    • Desolder the 4 connections of the green ribbon cable.
    • Pull upward on the green ribbon cable to separate it from the motherboard.
    • Be careful when pulling up the film as it may tear.
  14. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: stap 14, afbeelding 1 van 1
    • Using a #00 Phillips screwdriver, remove the two 1.4x3 mm screws securing the motherboard.
  15. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: stap 15, afbeelding 1 van 1
    • If the replacement motherboard does not have the wire battery terminals attached, desolder the two battery connections on the motherboard.
    • Leave the wire battery terminals in place.
    • If the replacement motherboard has battery terminals attached, the connections do not need to be desoldered.
  16. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: stap 16, afbeelding 1 van 1
    • To remove the battery terminals, use a prying tool to push the lip of the metal wire towards the motherboard.
    • Lift up on the wire while the small lip is depressed and slide the wire terminals out of the plastic guides.
    • Be careful not to bend the wire terminals.
  17. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: stap 17, afbeelding 1 van 2 Sony M-430 Microcassette-Corder Mechanism Deck Replacement: stap 17, afbeelding 2 van 2
    • Verify all of the connections have been desoldered and the screws removed.
    • Lift the motherboard upward to remove it from the microcassette-corder.
  18. Sony M-430 Microcassette-Corder Mechanism Deck Replacement, Mechanism Deck: stap 18, afbeelding 1 van 3 Sony M-430 Microcassette-Corder Mechanism Deck Replacement, Mechanism Deck: stap 18, afbeelding 2 van 3 Sony M-430 Microcassette-Corder Mechanism Deck Replacement, Mechanism Deck: stap 18, afbeelding 3 van 3
    • First, remove the buttons from the mechanism deck so that you can remove it from the case.
    • Find the tabs on each button.
    • Push the tab with a spudger away from the metal connection.
    • Pull button away from the mechanism deck to remove it.
  19. Sony M-430 Microcassette-Corder Mechanism Deck Replacement: stap 19, afbeelding 1 van 1
    • Remove the mechanism deck by lifting the tab as shown.
    What type of drive belt is that? How long is it? I can't seem to find the information online anywhere
    Shiny Krookodile - Antwoord
Conclusie
7 andere personen hebben deze handleiding voltooid.
Stephen
215 Reputatie
2 handleidingen geschreven
Cal Poly, Team 10-34, Amido Winter 2012 Lid van Cal Poly, Team 10-34, Amido Winter 2012
CPSU-AMIDO-W12S10G34
4 Leden
7 handleidingen geschreven
3 opmerkingen
I have to replace the capstan wheel of the driving mechanism. where do I get the above part? its Part NO. and app cost please. Thank you
Char.jp - Antwoord
I have cassettes, but recorder is not functioning for want of the capstan wheel of driving mechanism. Can you please help me with information
Char.jp - Antwoord
I would greatly appreciate receiving some info regarding where to get parts or a full mechanism deck replacement for Sony M-607V microcassette recorder. Also if it is possible to get a Service Manual with exploded views.
Thanks in advance for any help.
Hermann
Hermann Hugo Holbut Arroyo - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 40
Altijd: 6,128
