Ga door naar hoofdinhoud
Sony M-430 Microcassette-Corder Back Cover Replacement
Wat je nodig hebt
  1. Sony M-430 Microcassette-Corder Back Cover Replacement, Battery: stap 1, afbeelding 1 van 1
    • Find the arrow on the battery cover on the back of the device.
    • While pressing down on the arrow, slide the cover towards the bottom of the recorder until it clicks.
  2. Sony M-430 Microcassette-Corder Back Cover Replacement: stap 2, afbeelding 1 van 2 Sony M-430 Microcassette-Corder Back Cover Replacement: stap 2, afbeelding 2 van 2
    • Lift the cover and remove the batteries.
  3. Sony M-430 Microcassette-Corder Back Cover Replacement, Back Cover: stap 3, afbeelding 1 van 2 Sony M-430 Microcassette-Corder Back Cover Replacement, Back Cover: stap 3, afbeelding 2 van 2
    • Remove the battery cover by first tilting it so it is at a right angle with the rest of the device.
    • Next, twist it to the side as shown in the second picture. The lid should simply snap off.
    • Be careful not to apply too much force, as the lid may break.
  4. Sony M-430 Microcassette-Corder Back Cover Replacement: stap 4, afbeelding 1 van 2 Sony M-430 Microcassette-Corder Back Cover Replacement: stap 4, afbeelding 2 van 2
    • Use a #00 Phillips head screwdriver to remove the four (1.7x16 mm) screws from the back case.
    • Next, use the same screwdriver to unscrew the (1.7X5 mm) screw, which is located inside the battery compartment.
  5. Sony M-430 Microcassette-Corder Back Cover Replacement: stap 5, afbeelding 1 van 1
    • Use a spudger to push in the two tabs located on the bottom of the device.
    • It works best to push the tabs at an upward angle (towards the top of the battery compartment)
    • It may take a decent amount of force in order to push in the tabs.
  6. Sony M-430 Microcassette-Corder Back Cover Replacement: stap 6, afbeelding 1 van 1
    • With a firm grip on the larger half, remove the back cover by lifting first on the battery area.
    • The back cover should lift cleanly off.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Matt Teare
35 Reputatie
3 handleidingen geschreven
Cal Poly, Team 10-34, Amido Winter 2012 Lid van Cal Poly, Team 10-34, Amido Winter 2012
CPSU-AMIDO-W12S10G34
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 2,101
