Ga door naar hoofdinhoud
Sony ICF-C1T Tuner Dial Replacement
Wat je nodig hebt
  1. Sony ICF-C1T Tuner Dial Replacement, Tuner Dial: stap 1, afbeelding 1 van 1
    • Using the Phillips #00 screwdriver, remove four 14mm screws from the underside of the device.
    • Make sure that the clock is unplugged and the battery is removed before tampering with the device to avoid electrical shock.
  2. Sony ICF-C1T Tuner Dial Replacement: stap 2, afbeelding 1 van 1
    • Use the opening tool to pry apart the edges of the top and side portions of the device.
  3. Sony ICF-C1T Tuner Dial Replacement: stap 3, afbeelding 1 van 2 Sony ICF-C1T Tuner Dial Replacement: stap 3, afbeelding 2 van 2
    • Separate the device by gently pulling up on the top portion.
    • Use caution when pulling the device apart as the clock display is located close to the front face plate and is connected by multiple wires.
  4. Sony ICF-C1T Tuner Dial Replacement: stap 4, afbeelding 1 van 2 Sony ICF-C1T Tuner Dial Replacement: stap 4, afbeelding 2 van 2
    • To remove the motherboard, gently pull apart the sides of the device.
    • Do not pull hard on the motherboard, because it is still connected by multiple wires inside the device.
    • Be careful of sharp pieces on the motherboard.
    • Having help for this step might make things quicker and easier.
  5. Sony ICF-C1T Tuner Dial Replacement: stap 5, afbeelding 1 van 3 Sony ICF-C1T Tuner Dial Replacement: stap 5, afbeelding 2 van 3 Sony ICF-C1T Tuner Dial Replacement: stap 5, afbeelding 3 van 3
    • Remove the tuner dial by pulling it off of the motherboard. This can take a little force to remove.
Conclusie
Megan
275 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 26
Altijd: 1,514
