Inleiding
These instructions will guide you step-by-step to remove the door in order to get to the speakers inside
Wat je nodig hebt
Pull on tab away from the camera by applying pressure with index finger.
Bijna klaar!
Your door will now be disassembled in order to replace parts inside and these steps in reverse order will also help you put the door back together
Conclusie
