Ga door naar hoofdinhoud
Sony Handycam HDR-CX675 Lens Replacement
Wat je nodig hebt
  1. Sony Handycam HDR-CX675 Lens Replacement, Camera Shell: stap 1, afbeelding 1 van 1
    • The battery should be removed and oriented upwards.
  2. Sony Handycam HDR-CX675 Lens Replacement: stap 2, afbeelding 1 van 1
    • Remove the side 4.5 mm JIS #00 screw using JIS Screwdriver
    • Remove the 5.5 mm JIS #00 screw.
  3. Sony Handycam HDR-CX675 Lens Replacement: stap 3, afbeelding 1 van 2 Sony Handycam HDR-CX675 Lens Replacement: stap 3, afbeelding 2 van 2
    • Gently pry the plastic case surrounding the start/stop button free by using the blue plastic opening tools.
    • Remove the casing using your thumb and index finger.
  4. Sony Handycam HDR-CX675 Lens Replacement: stap 4, afbeelding 1 van 1
    • Turn the camera around and flip open the LCD screen to expose the side panel.
    • Remove the 5.5mm #00 screw using the J00 head screwdriver.
  5. Sony Handycam HDR-CX675 Lens Replacement: stap 5, afbeelding 1 van 1
    • Turn the camera to the handgrip side and unscrew two of the 5.5mm JIS #00 head screws using the JIS #00 head screwdriver.
  6. Sony Handycam HDR-CX675 Lens Replacement: stap 6, afbeelding 1 van 1
    • Remove the two 5.5mm JIS #00 screws with the bottom of the camera facing up.
  7. Sony Handycam HDR-CX675 Lens Replacement: stap 7, afbeelding 1 van 1
    • Turn the camera around in a way that the bottom of the camera is facing you.
    • Use the blue opening tool to gently remove the camera shell off of the camera.
  8. Sony Handycam HDR-CX675 Lens Replacement, Lens Cover Panel: stap 8, afbeelding 1 van 1
    • Using the blue plastic opener smoothly to take the camera shell off.
  9. Sony Handycam HDR-CX675 Lens Replacement: stap 9, afbeelding 1 van 2 Sony Handycam HDR-CX675 Lens Replacement: stap 9, afbeelding 2 van 2
    • Let the lens of the camera be pointed to your left.
    • Keep holding the camera with your right hand then gently remove the lens cover panel with your left hand.
  10. Sony Handycam HDR-CX675 Lens Replacement, Shutter Assembly: stap 10, afbeelding 1 van 1
    • Place the camera on its lens and keep the LCD screen open and pointed to your right.
    • Remove the 5.5mm JIS #00 screws from the hinge of the camera.
  11. Sony Handycam HDR-CX675 Lens Replacement: stap 11, afbeelding 1 van 2 Sony Handycam HDR-CX675 Lens Replacement: stap 11, afbeelding 2 van 2
    • Hold the camera with your left hand, and gently remove the shutter assembly part.
  12. Sony Handycam HDR-CX675 Lens Replacement: stap 12, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Hold the camera that the bottom is upwards and lens pointed to your left hand.
    • By the metal tweezers, remove the white wire that is connecting the shutter assembly and motherboard
  13. Sony Handycam HDR-CX675 Lens Replacement, Lens: stap 13, afbeelding 1 van 2 Sony Handycam HDR-CX675 Lens Replacement, Lens: stap 13, afbeelding 2 van 2
    • Use two fingers to twist and loosen the lens cover.
    • Remove the lens cover using the blue plastic opening tools.
  14. Sony Handycam HDR-CX675 Lens Replacement: stap 14, afbeelding 1 van 2 Sony Handycam HDR-CX675 Lens Replacement: stap 14, afbeelding 2 van 2
    • Unscrew the 5.5 mm JIS #00 screw that is holding the lens to the whole camera.
  15. Sony Handycam HDR-CX675 Lens Replacement: stap 15, afbeelding 1 van 2 Sony Handycam HDR-CX675 Lens Replacement: stap 15, afbeelding 2 van 2
    • The lens can easily be taken out.
Conclusie
Mohamed Nazer
403 Reputatie
3 handleidingen geschreven
USF Tampa, Team 8-2, Eyestone Spring 2017 Lid van USF Tampa, Team 8-2, Eyestone Spring 2017
USFT-EYESTONE-S17S8G2
3 Leden
8 handleidingen geschreven
Één opmerking
Why would one want to remove the camera lens?
I go to this site through Google search ‘HDR-CX675 wobbles, bobs, floats, drifts -lens’
I bought this camera and had it shipped to my non profit group in India. The user over there said the camera is broken.
She said the lens is floating, bobbing, drifting around with the camera off. That’s all I know. I said send the camera back to our headquarters. I need to look at this camera. If the lens is compromised which I cannot fathom why so I would need to fix it. One option is to follow these instructions in this great article. Thanks
C McReynolds - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 19
Altijd: 762
