Ga door naar hoofdinhoud
Sony Handycam HDR-CX675 Lens Cover Panel Replacement
Wat je nodig hebt
  1. Sony Handycam HDR-CX675 Lens Cover Panel Replacement, Camera Shell: stap 1, afbeelding 1 van 1
    • The battery should be removed and oriented upwards.
  2. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: stap 2, afbeelding 1 van 1
    • Remove the side 4.5 mm JIS #00 screw using JIS Screwdriver
    • Remove the 5.5 mm JIS #00 screw.
  3. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: stap 3, afbeelding 1 van 2 Sony Handycam HDR-CX675 Lens Cover Panel Replacement: stap 3, afbeelding 2 van 2
    • Gently pry the plastic case surrounding the start/stop button free by using the blue plastic opening tools.
    • Remove the casing using your thumb and index finger.
  4. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: stap 4, afbeelding 1 van 1
    • Turn the camera around and flip open the LCD screen to expose the side panel.
    • Remove the 5.5mm #00 screw using the J00 head screwdriver.
  5. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: stap 5, afbeelding 1 van 1
    • Turn the camera to the handgrip side and unscrew two of the 5.5mm JIS #00 head screws using the JIS #00 head screwdriver.
  6. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: stap 6, afbeelding 1 van 1
    • Remove the two 5.5mm JIS #00 screws with the bottom of the camera facing up.
  7. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: stap 7, afbeelding 1 van 1
    • Turn the camera around in a way that the bottom of the camera is facing you.
    • Use the blue opening tool to gently remove the camera shell off of the camera.
  8. Sony Handycam HDR-CX675 Lens Cover Panel Replacement, Lens Cover Panel: stap 8, afbeelding 1 van 1
    • Using the blue plastic opener smoothly to take the camera shell off.
  9. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: stap 9, afbeelding 1 van 2 Sony Handycam HDR-CX675 Lens Cover Panel Replacement: stap 9, afbeelding 2 van 2
    • Let the lens of the camera be pointed to your left.
    • Keep holding the camera with your right hand then gently remove the lens cover panel with your left hand.
Conclusie
Laith Al Hinai
161 Reputatie
1 Handleiding geschreven
USF Tampa, Team 8-2, Eyestone Spring 2017 Lid van USF Tampa, Team 8-2, Eyestone Spring 2017
USFT-EYESTONE-S17S8G2
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 15
Altijd: 814
