Ga door naar hoofdinhoud
Sony Handycam HDR-CX580V Recording Button Replacement
Wat je nodig hebt
  1. Sony Handycam HDR-CX580V Recording Button Replacement, Battery: stap 1, afbeelding 1 van 1
    • Locate the slider labeled "BATT" and pull it back from the battery with your thumb.
  2. Sony Handycam HDR-CX580V Recording Button Replacement: stap 2, afbeelding 1 van 1
    • At this point, you should be able to remove the battery by simply lifting it from the camera.
    • The camera provided for guide-creation did not include a battery. However, the battery position should be the same.
  3. Sony Handycam HDR-CX580V Recording Button Replacement, Recording Button: stap 3, afbeelding 1 van 3 Sony Handycam HDR-CX580V Recording Button Replacement, Recording Button: stap 3, afbeelding 2 van 3 Sony Handycam HDR-CX580V Recording Button Replacement, Recording Button: stap 3, afbeelding 3 van 3
    • Use the Phillips #00 head to remove the following 5.5mm screws on the left-hand side.
  4. Sony Handycam HDR-CX580V Recording Button Replacement: stap 4, afbeelding 1 van 1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the empty battery socket.
  5. Sony Handycam HDR-CX580V Recording Button Replacement: stap 5, afbeelding 1 van 1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the bottom.
  6. Sony Handycam HDR-CX580V Recording Button Replacement: stap 6, afbeelding 1 van 1
    • Fold back the hinging panel on the top of the camera located near the lens.
    • Use the Phillips #00 head to remove the following 5.5mm screws on the top under the hinging panel.
  7. Sony Handycam HDR-CX580V Recording Button Replacement: stap 7, afbeelding 1 van 2 Sony Handycam HDR-CX580V Recording Button Replacement: stap 7, afbeelding 2 van 2
    • Slide back the cover for the DC and A/V ports on the right-hand side.
    • Use the Phillips #00 head to remove the following 5.5mm screws underneath the cover and on the right-hand side.
  8. Sony Handycam HDR-CX580V Recording Button Replacement: stap 8, afbeelding 1 van 1
    • Use the plastic opener tool to loosen the casing on the bottom and the right-hand side.
    • At this point, the right-hand side should simply come off, although it will still be connected with internal wiring.
    • Be delicate with the wiring still attached to the side casing until you have access to removing them later.
  9. Sony Handycam HDR-CX580V Recording Button Replacement: stap 9, afbeelding 1 van 3 Sony Handycam HDR-CX580V Recording Button Replacement: stap 9, afbeelding 2 van 3 Sony Handycam HDR-CX580V Recording Button Replacement: stap 9, afbeelding 3 van 3
    • Carefully remove the bottom casing with your fingers.
    • Be careful not to loose the small metal stand-mount pieces that lay underneath the casing.
  10. Sony Handycam HDR-CX580V Recording Button Replacement: stap 10, afbeelding 1 van 1
    • Look at the right side of the camera (the side with the recording button) while holding back the detached casing.
    • Use the Phillips #00 head to remove the following 5.5mm screws near the recording button.
  11. Sony Handycam HDR-CX580V Recording Button Replacement: stap 11, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use the curved tweezers to carefully detach the blue ribbon cable connector from the body of the camera.
    • The recording button and its blue ribbon cable connector should become detached from the body, but remain connected to the top casing.
  12. Sony Handycam HDR-CX580V Recording Button Replacement: stap 12, afbeelding 1 van 2 Sony Handycam HDR-CX580V Recording Button Replacement: stap 12, afbeelding 2 van 2
    • Pull off the top casing by lightly grabbing either side and pulling towards the back of the camera.
  13. Sony Handycam HDR-CX580V Recording Button Replacement: stap 13, afbeelding 1 van 1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the inside of the top casing.
  14. Sony Handycam HDR-CX580V Recording Button Replacement: stap 14, afbeelding 1 van 1
    • Carefully remove the metal frame from the top casing.
  15. Sony Handycam HDR-CX580V Recording Button Replacement: stap 15, afbeelding 1 van 1
    • You are now free to remove the recording button, as well as its connection strip.
Conclusie
Derek Fritz
378 Reputatie
3 handleidingen geschreven
Texas Tech, Team S46-G5, Bennett Spring 2017 Lid van Texas Tech, Team S46-G5, Bennett Spring 2017
TTU-BENNETT-S17S46G5
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 21
Altijd: 442
