Ga door naar hoofdinhoud
Sony Handycam HDR-CX580V Battery Replacement
  1. Sony Handycam HDR-CX580V Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Locate the slider labeled "BATT" and pull it back from the battery with your thumb.
  2. Sony Handycam HDR-CX580V Battery Replacement: stap 2, afbeelding 1 van 1
    • At this point, you should be able to remove the battery by simply lifting it from the camera.
    • The camera provided for guide-creation did not include a battery. However, the battery position should be the same.
Conclusie
To replace a new battery, simply snap the battery into the slot from which you removed it from.
Één andere persoon heeft deze handleiding voltooid.
Joyelle Woodson
270 Reputatie
2 handleidingen geschreven
Texas Tech, Team S46-G5, Bennett Spring 2017 Lid van Texas Tech, Team S46-G5, Bennett Spring 2017
TTU-BENNETT-S17S46G5
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 494
