Inleiding
You will learn how to remove the lens cover panel without damaging your device.
Wat je nodig hebt
Rotate your camera such that the underside is facing you and the lens is facing the ground.
Orient the camera such that the lens is facing to your left.
Using your right hand to hold the camera, gently remove the lens panel from the camera with your left hand.
Één andere persoon heeft deze handleiding voltooid.
