Ga door naar hoofdinhoud
Sony Handycam HDR­-CX220 Motherboard Replacement
Wat je nodig hebt
  1. Sony Handycam HDR­-CX220 Motherboard  Replacement, Battery: stap 1, afbeelding 1 van 1
    • Push in the battery indicator.
  2. Sony Handycam HDR­-CX220 Motherboard  Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery out of the slot.
    • To put the battery back in, line up the battery's metal part with the camera's and slide it in.
  3. Sony Handycam HDR­-CX220 Motherboard  Replacement, Camera's Body: stap 3, afbeelding 1 van 3 Sony Handycam HDR­-CX220 Motherboard  Replacement, Camera's Body: stap 3, afbeelding 2 van 3 Sony Handycam HDR­-CX220 Motherboard  Replacement, Camera's Body: stap 3, afbeelding 3 van 3
    • Use the Phillips #0 screwdriver to remove the two 5mm screws.
    • Use the Phillips #0 screwdriver to remove the three 5mm screws.
  4. Sony Handycam HDR­-CX220 Motherboard  Replacement: stap 4, afbeelding 1 van 3 Sony Handycam HDR­-CX220 Motherboard  Replacement: stap 4, afbeelding 2 van 3 Sony Handycam HDR­-CX220 Motherboard  Replacement: stap 4, afbeelding 3 van 3
    • Use the plastic opening tool to loosen the plastic case of the camcorder.
  5. Sony Handycam HDR­-CX220 Motherboard  Replacement: stap 5, afbeelding 1 van 1
    • Use your hands to remove the plastic case.
    • Gently pull on the case not to damage anything internally.
  6. Sony Handycam HDR­-CX220 Motherboard  Replacement, Lens: stap 6, afbeelding 1 van 3 Sony Handycam HDR­-CX220 Motherboard  Replacement, Lens: stap 6, afbeelding 2 van 3 Sony Handycam HDR­-CX220 Motherboard  Replacement, Lens: stap 6, afbeelding 3 van 3
    • Use the Phillips #0 Screwdriver to remove the 5mm screw
    • Use the Plastic Opening tools to unhook the highlighted area.
  7. Sony Handycam HDR­-CX220 Motherboard  Replacement: stap 7, afbeelding 1 van 1
    • Remove the 3 (4mm) screws on the front of the lens using the Philips #0 Screwdriver.
  8. Sony Handycam HDR­-CX220 Motherboard  Replacement: stap 8, afbeelding 1 van 1
    • Remove the lens and clean it if needed.
  9. Sony Handycam HDR­-CX220 Motherboard  Replacement, Motherboard: stap 9, afbeelding 1 van 3 Sony Handycam HDR­-CX220 Motherboard  Replacement, Motherboard: stap 9, afbeelding 2 van 3 Sony Handycam HDR­-CX220 Motherboard  Replacement, Motherboard: stap 9, afbeelding 3 van 3
    • Use the Phillips #0 Screwdriver to remove the shown 5mm screws.
    • Use the plastic opening tool to release the front hook.
    • Use the plastic opening tool to release the back hook.
  10. Sony Handycam HDR­-CX220 Motherboard  Replacement: stap 10, afbeelding 1 van 2 Sony Handycam HDR­-CX220 Motherboard  Replacement: stap 10, afbeelding 2 van 2
    • Gently pull on the 2 wires shown on the bottom of the camcorder.
    • Disconnect the wire shows on the second picture.
  11. Sony Handycam HDR­-CX220 Motherboard  Replacement: stap 11, afbeelding 1 van 2 Sony Handycam HDR­-CX220 Motherboard  Replacement: stap 11, afbeelding 2 van 2
    • Use the Phillips #0 screwdriver to remove the 4mm screw shown.
    • Gently remove the motherboard with your fingers.
  12. Sony Handycam HDR­-CX220 Motherboard  Replacement: stap 12, afbeelding 1 van 2 Sony Handycam HDR­-CX220 Motherboard  Replacement: stap 12, afbeelding 2 van 2
    • Remove the side wire from the motherboard as shown on the photo.
    • Remove the top wire from the motherboard as shown on the photo.
  13. Sony Handycam HDR­-CX220 Motherboard  Replacement: stap 13, afbeelding 1 van 2 Sony Handycam HDR­-CX220 Motherboard  Replacement: stap 13, afbeelding 2 van 2
    • Unplug the speaker from the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Keven
811 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 8-5, Botvin Spring 2016 Lid van UMass Dartmouth, Team 8-5, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G5
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 1,043
