Inleiding
The replacement of the screen is needed if the image on the screen is not the desired image or if the screen is physically damaged.
Wat je nodig hebt
Use the Phillips #0 screwdriver to remove the two 5mm screws.
Use the Phillips #0 screwdriver to remove the three 5mm screws.
Use the Phillips #0 screwdriver to remover the two (5mm) screws on the outer part and one (3mm) in the middle.
In the second image, there is a second screw on the opposite side of the screen hinge. This screw is not shown, but must also be removed.
4 andere personen hebben deze handleiding voltooid.
3 opmerkingen
How do you mount hdr cx220 lcd cable flat? can you help me?
