Ga door naar hoofdinhoud
Sony Handycam HDR­-CX220 Display Screen Replacement
Wat je nodig hebt
  1. Sony Handycam HDR­-CX220 Display Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Push in the battery indicator.
  2. Sony Handycam HDR­-CX220 Display Screen Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery out of the slot.
    • To put the battery back in, line up the battery's metal part with the camera's and slide it in.
  3. Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: stap 3, afbeelding 1 van 3 Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: stap 3, afbeelding 2 van 3 Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: stap 3, afbeelding 3 van 3
    • Use the Phillips #0 screwdriver to remove the two 5mm screws.
    • Use the Phillips #0 screwdriver to remove the three 5mm screws.
  4. Sony Handycam HDR­-CX220 Display Screen Replacement: stap 4, afbeelding 1 van 3 Sony Handycam HDR­-CX220 Display Screen Replacement: stap 4, afbeelding 2 van 3 Sony Handycam HDR­-CX220 Display Screen Replacement: stap 4, afbeelding 3 van 3
    • Use the plastic opening tool to loosen the plastic case of the camcorder.
  5. Sony Handycam HDR­-CX220 Display Screen Replacement: stap 5, afbeelding 1 van 1
    • Use your hands to remove the plastic case.
    • Gently pull on the case not to damage anything internally.
  6. Sony Handycam HDR­-CX220 Display Screen Replacement, Display Screen: stap 6, afbeelding 1 van 2 Sony Handycam HDR­-CX220 Display Screen Replacement, Display Screen: stap 6, afbeelding 2 van 2
    • Use the Phillips #0 screwdriver to remover the two (5mm) screws on the outer part and one (3mm) in the middle.
    • In the second image, there is a second screw on the opposite side of the screen hinge. This screw is not shown, but must also be removed.
  7. Sony Handycam HDR­-CX220 Display Screen Replacement: stap 7, afbeelding 1 van 1
    • Use the plastic opening tool to remove the plastic case protecting the screen
    • Pull it gently not to damage anything under the case
  8. Sony Handycam HDR­-CX220 Display Screen Replacement: stap 8, afbeelding 1 van 2 Sony Handycam HDR­-CX220 Display Screen Replacement: stap 8, afbeelding 2 van 2
    • Use the Phillips #0 screwdriver to remove the 2 screws shown
    • Use your hands to carefully unhook the screen from the highlighted hook
  9. Sony Handycam HDR­-CX220 Display Screen Replacement: stap 9, afbeelding 1 van 3 Sony Handycam HDR­-CX220 Display Screen Replacement: stap 9, afbeelding 2 van 3 Sony Handycam HDR­-CX220 Display Screen Replacement: stap 9, afbeelding 3 van 3
    • Use your hands to carefully remove the tape
    • After removing the tape, pull on the wire disconnecting it from the screen.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Keven
811 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 8-5, Botvin Spring 2016 Lid van UMass Dartmouth, Team 8-5, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G5
3 Leden
12 handleidingen geschreven
3 opmerkingen
How do you mount hdr cx220 lcd cable flat? can you help me?
Rafael Oliveira - Antwoord
gjhgvnvyh n hygfv
ANM WORLD - Antwoord
We have a camera 220. Whose dipstick display strip has deteriorated again. Where can I find this strip? Video is good information so that's why
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 2,499
