Ga door naar hoofdinhoud
Sony Handycam HDR­-CX220 Buttons Replacement
Wat je nodig hebt
  1. Sony Handycam HDR­-CX220 Buttons  Replacement, Battery: stap 1, afbeelding 1 van 1
    • Push in the battery indicator.
  2. Sony Handycam HDR­-CX220 Buttons  Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery out of the slot.
    • To put the battery back in, line up the battery's metal part with the camera's and slide it in.
  3. Sony Handycam HDR­-CX220 Buttons  Replacement, Camera's Body: stap 3, afbeelding 1 van 3 Sony Handycam HDR­-CX220 Buttons  Replacement, Camera's Body: stap 3, afbeelding 2 van 3 Sony Handycam HDR­-CX220 Buttons  Replacement, Camera's Body: stap 3, afbeelding 3 van 3
    • Use the Phillips #0 screwdriver to remove the two 5mm screws.
    • Use the Phillips #0 screwdriver to remove the three 5mm screws.
  4. Sony Handycam HDR­-CX220 Buttons  Replacement: stap 4, afbeelding 1 van 3 Sony Handycam HDR­-CX220 Buttons  Replacement: stap 4, afbeelding 2 van 3 Sony Handycam HDR­-CX220 Buttons  Replacement: stap 4, afbeelding 3 van 3
    • Use the plastic opening tool to loosen the plastic case of the camcorder.
  5. Sony Handycam HDR­-CX220 Buttons  Replacement: stap 5, afbeelding 1 van 1
    • Use your hands to remove the plastic case.
    • Gently pull on the case not to damage anything internally.
  6. Sony Handycam HDR­-CX220 Buttons  Replacement, Buttons: stap 6, afbeelding 1 van 3 Sony Handycam HDR­-CX220 Buttons  Replacement, Buttons: stap 6, afbeelding 2 van 3 Sony Handycam HDR­-CX220 Buttons  Replacement, Buttons: stap 6, afbeelding 3 van 3
    • Use the Philips #0 screwdriver to unscrew the two 5mm screws shown on top of the camera.
    • Remove the one side 5mm screw using a Philips #0 Screwdriver.
    • Remove the top buttons from the hook.
  7. Sony Handycam HDR­-CX220 Buttons  Replacement: stap 7, afbeelding 1 van 2 Sony Handycam HDR­-CX220 Buttons  Replacement: stap 7, afbeelding 2 van 2
    • Unplug the connected wire shown.
    • Pull gently not to cause any damage.
Conclusie
Keven
811 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 8-5, Botvin Spring 2016 Lid van UMass Dartmouth, Team 8-5, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G5
3 Leden
12 handleidingen geschreven
Één opmerking
hi, can you please tell me where can I buyStep 6 Buttons?
thanks
jesus - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 899
