Inleiding
Can't record or capture moments with a cracked lens? This guide will take you through removing the outer casing and removal and replacement of the lens module.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Anti-Static Wrist Strap$7.95
Unfasten the hand strap.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Use the blunt tweezers to unplug the red and black wire by pulling out and away.
Unplug the small ribbon wire.
Unscrew the two right three 3mm Philips screws.
To reassemble your device, follow these instructions in reverse order in addition to the HDD replacement guide.
