Inleiding
Can't record or capture moments with a cracked lens? This guide will take you through removing the outer casing and removal and replacement of the lens module.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Anti-Static Wrist Strap$7.95
Unfasten the hand strap.
Bijna klaar!
To reassemble your device, follow these instructions in reverse order in addition to the HDD replacement guide.
Conclusie
