Ga door naar hoofdinhoud
Sony Handycam DCR-SR42 Lens Replacement
Wat je nodig hebt
  1. Sony Handycam DCR-SR42 Lens Replacement, Hard Drive: stap 1, afbeelding 1 van 2 Sony Handycam DCR-SR42 Lens Replacement, Hard Drive: stap 1, afbeelding 2 van 2
    • Remove the battery, and use the Phillips #00 precision screwdriver to then remove the three 3mm Phillips #00 screws under the battery.
    • Wait 1 hour after removing the battery before continuing to disassemble the camera.
  2. Sony Handycam DCR-SR42 Lens Replacement: stap 2, afbeelding 1 van 1
    • Remove the three 3mm #00 Phillips screws on the bottom of the camera.
  3. Sony Handycam DCR-SR42 Lens Replacement: stap 3, afbeelding 1 van 1
    • Remove the three 3mm Phillips #00 screws on the side of the camera.
    • Remove the 4mm Phillips #00 screw under the AV port cover.
  4. Sony Handycam DCR-SR42 Lens Replacement: stap 4, afbeelding 1 van 2 Sony Handycam DCR-SR42 Lens Replacement: stap 4, afbeelding 2 van 2
    • Gently pull the black plastic hard drive cover away from the body of the camera. This will expose the hard drive.
    • Even with all the screws removed, this part will require some force to remove.
  5. Sony Handycam DCR-SR42 Lens Replacement: stap 5, afbeelding 1 van 2 Sony Handycam DCR-SR42 Lens Replacement: stap 5, afbeelding 2 van 2
    • Lift the hard drive out of the camera by grasping the grey rubber mounting brackets and pulling them upwards.
    • The hard drive is attached to the flex cable. Remove the hard drive slowly to prevent the flex cable from being damaged.
  6. Sony Handycam DCR-SR42 Lens Replacement: stap 6, afbeelding 1 van 1
    • Remove the rubber mounting brackets by pulling them off the hard drive.
  7. Sony Handycam DCR-SR42 Lens Replacement: stap 7, afbeelding 1 van 1
    • Carefully unplug the flex cable from the hard drive.
  8. Sony Handycam DCR-SR42 Lens Replacement, Internal Components: stap 8, afbeelding 1 van 2 Sony Handycam DCR-SR42 Lens Replacement, Internal Components: stap 8, afbeelding 2 van 2
    • Remove the four 3mm Phillips #00 screws from under the hard drive.
  9. Sony Handycam DCR-SR42 Lens Replacement: stap 9, afbeelding 1 van 3 Sony Handycam DCR-SR42 Lens Replacement: stap 9, afbeelding 2 van 3 Sony Handycam DCR-SR42 Lens Replacement: stap 9, afbeelding 3 van 3
    • Press in on the two tabs as shown and lift the metal plate up and off the camera.
  10. Sony Handycam DCR-SR42 Lens Replacement: stap 10, afbeelding 1 van 3 Sony Handycam DCR-SR42 Lens Replacement: stap 10, afbeelding 2 van 3 Sony Handycam DCR-SR42 Lens Replacement: stap 10, afbeelding 3 van 3
    • Remove the two 4mm Phillips #00 screws from the underside of the camera.
    • Remove the 2 mm Phillips #00 screw from the screen hinge.
    • Remove the two 6mm Philips #00 screws from the side
  11. Sony Handycam DCR-SR42 Lens Replacement: stap 11, afbeelding 1 van 3 Sony Handycam DCR-SR42 Lens Replacement: stap 11, afbeelding 2 van 3 Sony Handycam DCR-SR42 Lens Replacement: stap 11, afbeelding 3 van 3
    • Use the plastic opening tool to remove the plastic cover from the top of the camera.
    • Remove the two 3mm Phillips #00 screws from underneath the plastic cover.
  12. Sony Handycam DCR-SR42 Lens Replacement: stap 12, afbeelding 1 van 2 Sony Handycam DCR-SR42 Lens Replacement: stap 12, afbeelding 2 van 2
    • Remove the second plastic cover from the top of the camera.
    • Remove the 4mm Phillips #00 screw from underneath the cover.
  13. Sony Handycam DCR-SR42 Lens Replacement: stap 13, afbeelding 1 van 2 Sony Handycam DCR-SR42 Lens Replacement: stap 13, afbeelding 2 van 2
    • Carefully pry the screen assembly apart from the main body of the camera.
    • Unplug the flex cable from the screen assembly.
  14. Sony Handycam DCR-SR42 Lens Replacement, Lens: stap 14, afbeelding 1 van 1
    • Remove the 3mm Phillips #00 screw from the underside of the camera near the lens housing.
  15. Sony Handycam DCR-SR42 Lens Replacement: stap 15, afbeelding 1 van 2 Sony Handycam DCR-SR42 Lens Replacement: stap 15, afbeelding 2 van 2
    • Use the plastic opening tool to pry the side casing off the camera.
  16. Sony Handycam DCR-SR42 Lens Replacement: stap 16, afbeelding 1 van 1
    • Remove the final 3mm #00 Phillips screw from the lens housing.
  17. Sony Handycam DCR-SR42 Lens Replacement: stap 17, afbeelding 1 van 1
    • Remove the lens housing from the camera.
  18. Sony Handycam DCR-SR42 Lens Replacement: stap 18, afbeelding 1 van 1
    • Remove the three 2mm Phillips #00 screws from around the lens.
  19. Sony Handycam DCR-SR42 Lens Replacement: stap 19, afbeelding 1 van 1
    • Remove the lens from the camera.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Dan Muller
1.020 Reputatie
5 handleidingen geschreven
Baylor, Team 7-13, Williams Spring 2015 Lid van Baylor, Team 7-13, Williams Spring 2015
BU-WILLIAMS-S15S7G13
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 764
