Ga door naar hoofdinhoud
Sony Handycam DCR-DVD103 Outer Cover Replacement
Wat je nodig hebt
  1. Sony Handycam DCR-DVD103 Outer Cover Replacement, Battery: stap 1, afbeelding 1 van 1
    • Images do not show the camera's battery.
    • On the back of the camera beneath the viewfinder, locate the battery pack.
    • Press the small button.
    • Slide the switch forward.
  2. Sony Handycam DCR-DVD103 Outer Cover Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery from the camera.
    • To reinsert the battery, slide the battery into the camera.
  3. Sony Handycam DCR-DVD103 Outer Cover Replacement, Outer Cover: stap 3, afbeelding 1 van 1
    • Using a #00 Phillips screwdriver, remove the six 4.5 mm screws from the camera's bottom.
  4. Sony Handycam DCR-DVD103 Outer Cover Replacement: stap 4, afbeelding 1 van 2 Sony Handycam DCR-DVD103 Outer Cover Replacement: stap 4, afbeelding 2 van 2
    • Remove the three 4.5 mm screws beneath the battery.
    • Remove the 2.9 mm screw from the right corner.
    • Remove the two 4.5 mm screws from the battery's right wall.
    • Images do not show the battery.
  5. Sony Handycam DCR-DVD103 Outer Cover Replacement: stap 5, afbeelding 1 van 1
    • Remove the 4.5 mm screw under the output flap on the front of the camera below the lens.
  6. Sony Handycam DCR-DVD103 Outer Cover Replacement: stap 6, afbeelding 1 van 2 Sony Handycam DCR-DVD103 Outer Cover Replacement: stap 6, afbeelding 2 van 2
    • Remove the two 4.5 mm screws at the top of the camera.
    • Remove the 4.5 mm screw from the disk side of the camera (next to the lens).
  7. Sony Handycam DCR-DVD103 Outer Cover Replacement: stap 7, afbeelding 1 van 2 Sony Handycam DCR-DVD103 Outer Cover Replacement: stap 7, afbeelding 2 van 2
    • Extend the gray viewfinder, then gently remove the black plastic casing.
    • Caution: Plastic pieces are fragile.
  8. Sony Handycam DCR-DVD103 Outer Cover Replacement: stap 8, afbeelding 1 van 1
    • Remove the two 2.9 mm screws under the black plastic casing.
  9. Sony Handycam DCR-DVD103 Outer Cover Replacement: stap 9, afbeelding 1 van 1
    • Gently pull apart the outer silver case and screen.
    • Remove the copper wire strip to detach the case from the camera.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
kaitlin
342 Reputatie
3 handleidingen geschreven
Cal Poly, Team 7-44, Regan Winter 2011 Lid van Cal Poly, Team 7-44, Regan Winter 2011
CPSU-REGAN-W11S7G44
5 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,438
