Ga door naar hoofdinhoud
Sony HDR-AS30V Outer Casing Replacement
Wat je nodig hebt
  1. Sony HDR-AS30V Outer Casing Replacement, Outer Casing: stap 1, afbeelding 1 van 1
    • Power off the device. Remove the component jack cover.
    • Open component door.
    • Using the Phillips 00 screwdriver, remove the two screws holding the jack cover in place.
  2. Sony HDR-AS30V Outer Casing Replacement: stap 2, afbeelding 1 van 1
    • Open the battery door.
    • Slide the battery cap along the length of the camera, then flip the cap outward. Use caution; there may be internal damage affecting the functionality of the sliding mechanism.
  3. Sony HDR-AS30V Outer Casing Replacement: stap 3, afbeelding 1 van 1
    • Prepare to remove outer casing.
    • Using the 2.5 mm precision slotted screwdriver, insert the tip of the screwdriver under the holder to wedge. Use caution when preparing to wedge apart fragile components.
  4. Sony HDR-AS30V Outer Casing Replacement: stap 4, afbeelding 1 van 1
    • Separate Casing from Device.
    • With the screwdriver wedged, apply slight force while pulling the casing away from the device. Use caution to avoid causing damage to fragile parts.
  5. Sony HDR-AS30V Outer Casing Replacement: stap 5, afbeelding 1 van 1
    • With the outer casing pulled away from the device, take note of the orientation of the inner component to avoid an electrical short.
    • Once the orientation of the inner component is noted, slide the inner component out of the casing. You may now replace the broken casing with a new one.
Conclusie
Patrick Finney
101 Reputatie
1 Handleiding geschreven
Penn State, Team 2-12, Kaschak Winter 2015 Lid van Penn State, Team 2-12, Kaschak Winter 2015
PSU-KASCHAK-W15S2G12
4 Leden
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 1,042
