Inleiding
This is a comprehensive guide on how to fix and replace the LCD screen for Sony HDR-AS30V.
Wat je nodig hebt
Power off the device. Remove the component jack cover.
Open component door.
Using the Phillips 00 screwdriver, remove the two screws holding the jack cover in place.
With the outer casing pulled away from the device, take note of the orientation of the inner component to avoid an electrical short.
Once the orientation of the inner component is noted, slide the inner component out of the casing. You may now replace the broken casing with a new one.
Één andere persoon heeft deze handleiding voltooid.
