Inleiding
Here’s how to replace the right ear pad on your Sony h.ear on 3 headphones.
(You might see tape on the headphone arches in photos. This is because my headphones have broken along this casing and while disassembling, it simplifies repair to keep that area fixed together.)
Note: This guide used to be for both ear pads but I decided to make it just for one and make the other it's own guide to make all the guides for these headphones easier to read and work with.
Wat je nodig hebt
Extend the Right cup and fold the Left cup away via the headband .
The pad is attached by 6 clips in a hexagonal pattern, shown by the arrows.
Starting from the top, insert an opening pick in between where the cup leather meets the plastic casing, push it in firmly, then twist it until you disengage the top clip.
Work round the back side, poking the pick in and twisting to disengage further clips until you can gently pull the cup away.
Één andere persoon heeft deze handleiding voltooid.
