Inleiding
The Left Speaker housing on the Sony h.ear on 3 contains the following components:
- The mainboard.
- Another connected board that has all of the buttons, ports and the microphone used for calls.
- NFC antenna.
You also need to disassemble the Left Speaker housing to fully remove the headband.
I don’t have the tools or skills to disassemble most of the parts here (only the headband), so this guide is if you want to access this area and perform your own further disassembly.
Wat je nodig hebt
Extend the Left cup and fold the Right cup away via the headband.
This will help protect the other ear pad while you work on this one.
The pad is attached by 6 clips in a hexagonal pattern, shown by the arrows.
Starting from the top, insert an opening pick in between where the cup leather meets the plastic casing, push it in firmly, then twist it until you disengage the top clip.
Work round the back side, poking the pick in and twisting to disengage further clips until you can gently pull the cup away.
Check that you are on the Left Speaker using the indicator on the headband.
Use a JIS #000 screwdriver to remove the 5x 6mm screws holding the Left Speaker casing in place.
Gently lift the cup away and peek inside without fully removing it. You should see the following:
A thin layer of tape holding a cable going from the boards to the NFC antenna in the outer shell piece.
Another thin layer of tape below it holding the headband cable and NC microphone cables to the mainboard.
Gently pry the layer of tape holding the NFC cable.
Once you've done that, it should have enough slack, and then you can open it like a book from the right side.
Before re-installing the cups, test your headphones to make sure they turn on and work in a basic way.
For the best re-assembly, you may need to replace the foam tape.
