Ga door naar hoofdinhoud
Sony Ericsson z300 Microphone Replacement
Wat je nodig hebt
  1. Sony Ericsson z300 Microphone Replacement, Back Phone Cover: stap 1, afbeelding 1 van 1
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Sony Ericsson z300 Microphone Replacement, Battery: stap 2, afbeelding 1 van 1
    • Using a fingernail lift the battery out of the phone.
  3. Sony Ericsson z300 Microphone Replacement, Sim Card: stap 3, afbeelding 1 van 1
    • Slide the sim card out with your thumb.
  4. Sony Ericsson z300 Microphone Replacement, Back Dark Grey Case: stap 4, afbeelding 1 van 1
    • To remove the back case first remove the four screws shown with a T5 Torx screwdriver
  5. Sony Ericsson z300 Microphone Replacement: stap 5, afbeelding 1 van 1
    • Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
  6. Sony Ericsson z300 Microphone Replacement: stap 6, afbeelding 1 van 1
    • Lift up towards the bottom and slide the case off.
  7. Sony Ericsson z300 Microphone Replacement, Motherboard: stap 7, afbeelding 1 van 1
    • Use a plastic opening tool to lift up the brass colored panel.
  8. Sony Ericsson z300 Microphone Replacement: stap 8, afbeelding 1 van 1
    • Flip up the yellow tab using a plastic opening tool to disconnect the motherboard from the phone body.
  9. Sony Ericsson z300 Microphone Replacement: stap 9, afbeelding 1 van 1
    • Work the plastic opening tool around the edges of the motherboard to release it from the clips.
  10. Sony Ericsson z300 Microphone Replacement, Keypad: stap 10, afbeelding 1 van 1
    • Using a plastic opening tool lift up the keypad to remove it.
  11. Sony Ericsson z300 Microphone Replacement, Microphone: stap 11, afbeelding 1 van 1
    • Use a plastic opening tool to lift the microphone out of its circular slot.
Conclusie
Alex Serventi
65 Reputatie
13 handleidingen geschreven
Cal Poly, Team 5-15, Maness Fall 2010 Lid van Cal Poly, Team 5-15, Maness Fall 2010
CPSU-MANESS-F10S5G15
4 Leden
26 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,874
